Results 1 to 10 of 15
Thread: cdti 150 engine wine?
    Regular Member sr150i's Avatar
    Oct 2010
    belfast
    Default cdti 150 engine wine?
    any one had this prob?awful wine from my engine?
    had the timing belt,water pump and fan belft tensioner replaced so its not them?
    my mate said it mite be the aircon pump?
    if so wat has to be done to sort it except a new one of corse..
    thanks
    Regular Member mozzer99's Avatar
    bristol
    If it whines when the air con is on then it needs servicing, though it may be too late (the refrigerant carries an oil mist to lubricate - low gas means low oil flow).
    If it whines with air con off, then just the pulley bearing can be changed.
    Possible to do it on the car without draining the aircon refrigerant.
    Oct 2010
    belfast
    ok mate cheers..were would i get one of these bearings?i actuly left the car to vauxhall and they told me they couldint find the problem fs
    West
    get your head under the bonnet while someone holds the revs down, it may help in determining where the whine is coming from... 1 possibility is alternator bearings.
    Oct 2010
    belfast
    tho the altonater was chaged not so long ago
    Bristol
    Vehicle : CDTI 150
    Remove the aux drive belt and then run the engine, if noise disappears its something that runs off the belt e.g. alt or air con compressor.
    If the noise is still there then its something else.
    Oct 2010
    belfast
    yea its deff one of them then i did that today.hmmmm
    Chelmsford
    wine from the engine?! brilliant! red or white?!
    Oct 2010
    belfast
    Quote Originally Posted by DNS View Post
    lol..wish it was that kind of wine..it wouldin be driving me insane
    Bristol
    Vehicle : CDTI 150
    with the belt off and engine off rotate each pulley including the tensioner, check for smooth/quiet operation.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. wine
    By happypostie in forum General Chat
    Last Post: 1st September 2010, 15:27
  3. WINE flu hits the UK
    By Big Knox in forum The 'Off Topic' room
    Last Post: 15th June 2009, 11:44
  4. Rose wine
    By Big Sig in forum The 'Off Topic' room
    Last Post: 23rd June 2008, 22:20
  5. Tesco Wine offer
    By siadwel in forum General Chat
    Last Post: 31st October 2007, 00:55
what enginewine will need in 150 engine
