Thread: V6CDTi - Valve clearance values - URGENT -
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default V6CDTi - Valve clearance values - URGENT -
    Taking the car to my mechanic tomorrow to replace all 6 injectors so while the rocker covers will be off I was thinking we could readjust the valves. I could't find the clearance values myself, so could any of you please check? Inlet - Exhaust valves, warm - cold engine.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Need this info in the next few hours if possible!
    Full Member Big Sig's Avatar
    I hope this is quick enough, its the only clearance tolerances I can see.
    Check 4x valve play, cylinder-1
    • With feeler gauge
    Note: Check valve play with the engine cold - room temperature.
    – Test values: Intake valves/exhaust valves 0.40 mm!
    35. Turn crankshaft
    Note: Turn crankshaft evenly. Turn crankshaft evenly until KM-6380 (1) (intake side) can be inserted. Note differing tool designs for intake and exhaust valves.
    • Marking - IN = Intake side
    – Marking - EX = Exhaust side
    Important: The valves may not strike the crown of the piston! Use a suitable cover (2) to seal oil bores and camshaft housing over the entire width! The adjusting discs can slip or stick.
    36. Adjust 2x intake valve play - cylinder-1 (part 1)
    • Use KM-609-6 (3)
    • Turn valve lifter until lifter groove points outwards
    • Valve lifter with KM-6380 (1)
    37. Adjust 2x intake valve play - cylinder-1 (part 2)
    • Lever out adjusting disc (4) with screwdriver (5)
    • Example for determining the thickness of the adjusting disc
    – Thickness of the adjusting disc fitted plus valve play measured minus preset value produces the thickness of the new adjusting disc
    • Insert adjusting disc
    Note: Coat new adjusting disc with engine oil. Insert in valve lifter with marking pointing downwards
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Cheers for the info mate
  1. Valve Clearance check with Cambelt change
    By LeeU in forum Y & Z30DT Specific
    Last Post: 6th April 2012, 00:51
  2. V6CDTi - Valve shim diameter
    By Celes in forum Engine & Drivetrain
    Last Post: 15th January 2011, 22:26
  3. adjusting valve clearance 150cdti
    By hairy31 in forum Engine & Drivetrain
    Last Post: 12th January 2011, 20:08
  4. V6CDTi coolant loss - heater bypass valve?
    Last Post: 6th October 2010, 17:50
