Thread: just check my fault codes
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    Default just check my fault codes
    just done the pedal test and results told me it was fault code 2110 which is fuel volume regulator control circuit low does any1 no wat this means please !!! cheers also front wiper motor relay circuit open that was my 2 fault codes!!
    Dec 2010
    belfast
    dose any1 no wat these r ,thnx
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Guessing - Fuel regulator/pump is faulty?
    As for the wiper motor relay open fault; if the wipers work fine then ignore it. Probably a blip and it has been stored.
    Gazza4
    Dec 2010
    belfast
    cheers gazza, does that mean i need 2 buy a new fuel pump m8 r is there an other way around it!!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by wallace78 View Post
    It's a guess m8 just reading the fautl the way it says. There could be any number of things. Has the fuel filter been changed? What are the tolerances on the Injectors? Are the leak offs ok? etc.
    The fuel pump could be fine.
    Gazza4
    Dec 2010
    belfast
    yes m8 i just changed the fuel filter!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Maybe see about the others. Point is as I understand it fuel pumps are expensive. Best to eliminate the cheaper first. Take it to a mechanic you are comfortable with and confident in finding the fault.
    Gazza4
    Dec 2010
    belfast
    no probs, cheers again gazza!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No problem.
    Gazza4
  1. fault codes
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2012, 17:30
  2. fault codes
    By GSi-Col in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2012, 00:00
  3. fault codes
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 21:12
  4. Fault Codes
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 21:39
  5. fault codes need help please
    By madmark in forum Engine & Drivetrain
    Last Post: 21st May 2009, 21:37
