Thread: Water leak - dash removal
    Nov 2010
    Ballymena, Northern Ireland
    Default Water leak - dash removal
    Hi there,
    I have a water leak on the passenger side which I think is coming from the windscreen / wing / A-pillar area where they all meet, but only when the car is parked on a slope (front up)
    I have checked the pollen filter drains and re-sealed the pollen filter itself.
    I also replaced the windscreen so it can't be that.
    I've had the wing off and sealed where I though it was getting in, but its still leaking so I'm going to take the dash out as the next step..
    Bigmac has suggested that it could be the trims on the roof, but I can get the leak to happen with just pouring water on the bottom corner of the windscreen.
    Any suggestion guys?
    Thanks in advance
    Stewart
    Regular Member Jezzy's Avatar
    S.E
    I've heard of one case similar to yours, where the guy thought it must be the windscreen, but I kept insisting it was the pollen filter/drain hole as the water was on the passenger side, even though he said he'd checked it several times. It turned out the pollen filter plastic housing had warped and slightly come away from the bulkhead.
    Nov 2010
    thanks, but its definitely not that - I had removed the pollen filter and resealed it - its bone dry behind there..
    When I pour the water to reproduce the leak, the water doesn't go over that far..
    In fact I can see the water dripping down when I remove the passenger door seal and the little plastic door on the end of the dash and look up the side of the dash
    Kingston Upon Hull
    I had a leek in the boot i found it was coming in were the roof rack fitted. i removed the trim that goes from the front to rear of the car on the roof and found louse pop rivets it could be the same at the front of the roof and water running down the pillar
    Its just a idea worth a look / check
    Jacko
    Mine did that, a cable near the pollen filter which goes through a rubber grommet had been pulled at some point and the rubber grommet had come out leaving a big hole. The water ran down the cable into the foot well.
  1. Water leak!
    By daddy5times in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2013, 17:14
  2. Water Leak
    By Chris SRi in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:43
  3. water leak
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 19:50
  4. Water Leak
    By acame2000 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 10:17
  5. water leak
    By zubs187 in forum Engine & Drivetrain
    Last Post: 22nd July 2007, 18:17
2007 vectra removing passenger side pillar windscreen
