Thread: Warning Sign
    Regular Member Andy M's Avatar
    Surrey
    Unhappy Warning Sign
    Hi guys. i have a bit of a problem which the garage can't solve. My brake pad warning light is randomly coming on in the display. Firstly I had the brake pads and detector wires checked. All well. Next I had them wire up the compu ter to check the problem - no record that the warning light had been on. Now coming home came on again. Won't be on in the morning. It's bl**dy irritating driving along with a picture of a brake pad warning light next to your speedo. Any ideas ????
    cheers
    if it lights the indicator then it should log a code..
    did they check the sensor wire for continuity?? may have a fracture in the wire
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Is this a light to tell you that the pads are worn?
    Surrey
    Yes, this is the light to say the pads are worn. They both checked the sensor wire in the pads and the computer for codes but nothing was there. It's been on on about 5 occasions - no record ?
    Regular Member Flyingkiwi's Avatar
    Jun 2006
    Mytchett, Surrey
    Hi,
    I had exactly the same problem with my 03 Diesel SXi. Never could get rid of it. Had the brakes, pads and wiring checked several times...
    Would go off for a couple of days, then disappear....then come on again.
    Was like it up to when I sold it. When I asked about it later, my regular vauxhall dealer said it never happened again whilst they had it to sell on...
    Weird
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Might be something to do with the contacts, Vx had a problem with spurious results from gold contacts and replaced them with carbon in 06.
    Or it might be due to vibration, depending on how the sensor works.
    Mine did this, i put a new wire on ( £8 ) cured it.
    Quote Originally Posted by prm
    I reckon this is your first port of call matey.
    I also reckon that you should ask a different 'fitter' to Tech2 your car and look for any fault codes. Most of them don't know how to use this machine properly.
    Surrey
    thanks for these. i'll try the new wire
    I've just helped (watched ) Drinky change the discs and pads on my car and the wire looks very fragile. If it only costs £8 for a new one, you can either rule it out or fix it with very little dollar.
    Just in case you're not aware the wire can be found on the front passenger side on the inside pad.
  1. what's this sign mean...
    By ShaunyB23 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2011, 16:27
  2. Help - Steering wheel warning sign??
    By mishima in forum Engine & Drivetrain
    Last Post: 19th February 2011, 13:59
  3. 888 sign Gio
    By dh.dti in forum Motorsport / Formula 1 etc. chat
    Last Post: 4th April 2010, 21:10
  4. Help re warning sign
    By m1ke823146 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 09:38
  5. I've Been Given A Sign
    By VauxVeteran in forum General Chat
    Last Post: 7th July 2008, 18:09
