Thread: having problems with my insignia clutch!!! help please
    Apr 2008
    murton seaham
    Default having problems with my insignia clutch!!! help please
    i think there is a problem with my insignia sri 160 cdti on a 10 plate with 10k miles on
    firstly when i lightly rest my foot on clutch pedal it starts to vibrate at the top untill depressed half way down then goes off
    secondly 1st to 4th gear seems difficult to engage to the point of a grind/clunk into gear
    when in gear and accelarate moderatly hard i get the same vibrate through the gear stick in lower gears
    in lower gears up to 4th when you coast along then accelarate you get a clunk when power kicks in and when you let your foot off the accelarator same again
    does anyone have any ideas about whot this could be before i go to stealers thanks in advance
    london
    sounds like DMF problem from your description and based on what I've read elsewhere on here. someone more wise will probably be alkong to confirm or correct what I've suggested though......
    Apr 2008
    murton seaham
    anyone any ideas as going to stealers in morning to do a road test
    Sodding Typical on Sea
    Sounds like the DMF is out of balance and possibly the slave has failed to me,,,, 10K is too little miles for the friction plate to be worn through I would have thought but hey!
  1. insignia dmf and clutch
    By tonyord in forum Insignia car chat
    Last Post: 4th March 2012, 18:04
  2. Clutch Problems??
    By trublu24 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 13:18
  3. Clutch Problems
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2008, 14:47
