Results 1 to 10 of 11
Thread: hid problem
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default hid problem
    hi all ive had my hid kit on for a while it never strobes or flickers but the one thing it does drives me insane!! when i turn the lights on most of the time one of them doesnt come on first time and i have to keep turning the light switch on and off until it kicks in and that happens to both of them??? any ideas what it could be??
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    I have literally tried everything this week, been happening to me, the exact same thing
    I have asked hids direct for another ballast so will see what i get back, my next thing to try is to tech 2 the car to say its got xenon
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Assuming its an after market kit have you tried swapping the ballasts around? There's not much to go wrong with them, bulb, ballast, canceller(if fitted) or the 2 spade connectors. If its the ballast you can pick one up pretty cheaply off ebay, even from UK sellers.
    Aug 2010
    York
    Its hard to diagnose cause it works sometimes, I have literally same issue as OP. I have tried with and without cancellors. But still under warranty so gonna try gettin a new one out to test, Mine flashes and just never fires up. Like there is not enough power
    Feb 2007
    i have tried everything the set i have was previously on my mondeo and i added the cancellors to them for the vec on the mondeo i never had a problem at all i think im just going to have to live with it as i cant go back to normal bulbs
    Aug 2010
    York
    Quote Originally Posted by vectragsi3.2 View Post
    I know what you mean I love em, what kit have you got? Cause if all else fails I was gonna try like a canbus pro kit, or get it tech 2 or something
    Feb 2007
    cant remember what kit it is it was bought from ebay a while ago ive got it tech 2'd but it hasnt seemed to have done anything
    Full Member pattz123's Avatar
    Motherwell
    6 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    I had similar issues with my hids, lots of flickering b4 firing up and then stop working. I found the connections at one of the plugs poor so i cut the plug off and reconnected using heat shrink crimps, working fine ever since no flickering 6 months on. 50w 6000k hids from hids direct.
    Aug 2010
    York
    Thanks for that I wont bother with the tech 2, i dont have flickering or anythin just fails to power up.
    I did check connections but will have another look. Just a pita to take out and send back.
    Symington (Biggar)
    Have had the same problem with firing up intermittently, I have cut off all the connectors and put on bullet connectors, no issues since
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
