Results 1 to 10 of 24
Thread: cdti 150..very smokey,lagy...help please!
    Regular Member sr150i's Avatar
    Oct 2010
    belfast
    Unhappy cdti 150..very smokey,lagy...help please!
    ok here it goes...
    i have a 2005 sri 150 i bought about 5 months ago..
    always thought they were a lively enuf thing..
    but ever since having it its giveing out loads of smoke on boost?it fils the road with suit and i can notice this more when dark and i look in my rear view with other cars headlights!..
    and sometime when i boost it on it cuts out at the spanner comes on the dash?and the EML some times aswel
    the car is very lagy it takes for ever to come on boost..
    some people are saying manifold swirl valves?
    egr valve?-why would it have lots of lag?
    boost sensor?-but why would it be smoney?
    any one else had simalor problems?
    thanks
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Ok at the moment I suspect either:
    - Check Swirl bar rod/Swirls move when engine is revved above 2,500rpm.
    - EGR valve
    - Split hose
    - Boost sensor is dirty
    Check swirl bar - is it off? Remove engine vanity cover and look down behind the fuel rail (large silver tube onto of the engine). You will see a metal linkage if this is off it could be source of your troubles. If is working is there any oil sweat? If so swirl flaps are on the road out or have failed. If the rod is still connected check it moves by getting someone to rev it past 2,500rpm while you watch. If it doesn't move the drive module is knackered. However this usually puts on the EM light.
    Have look, purchase EGR gaskets from the Dealer and clean the EGR valve and replace.
    Check all hoses for splits - particularly the one heading to the manifold (large rubber hose wnich sits between the engine and battery compartment - it heads into the engine).
    Give boost sensor a clean as per How2.
    If it's not any of the above then I would say the intercooler has split - quite common.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Oct 2010
    belfast
    thanks alot mate..it check these things in the morning and let u know how i get on thanks again!
    Oct 2010
    belfast
    also wats DPF blockage?
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by sr150i View Post
    Unless yours is auto it won't affect you m8.
    Gazza4
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    also check the small vacum hose at the front cross member
    Oct 2010
    belfast
    ok went out in the vectra tonite and it wont go over 3000 rpm! i swear i would have set it on fire the mood it has put me in..i kept having to turn the engine off and restart it so it would boost for the cuple of seconds then cut out again!!!..
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Sounds like a loss of boost any way. More likely the intercooler tbh as it has the same symptoms mine did, but check the boost hose and hose coming out of the MAF first.
    Gazza4
    Oct 2010
    belfast
    all my we boost hoeses under the engine cover need replaceing but would this be the prob?the car was driving 120% until the last cuple of days..and i bet intercoolers afrent cheap!
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Intercooler - £500ish.
    How do you know they need replacing? Are they split?
    Gazza4
  1. Smokey Vec
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 15:57
  2. Smokey V6 CDTI after idling...
    By myveccy in forum Engine & Drivetrain
    Last Post: 17th May 2010, 15:41
  3. Smokey Sri
    By MarkEllo220864 in forum Engine & Drivetrain
    Last Post: 27th March 2009, 11:56
  4. Smokey CDTI
    By MattW in forum Diesel Engine related
    Last Post: 21st September 2008, 00:32
  5. Smokey V6 CDTI SRI
    By woodster in forum Engine & Drivetrain
    Last Post: 23rd August 2005, 09:21
