Results 1 to 2 of 2
Thread: Clutch problem (sticking)
    Belfat (NI)
    Default Clutch problem (sticking)
    Hi have 2005 vectra c estate 120 19dcti. Got a new fly wheel, clutch, master a slave cylinder also replaced the pedal spring. Car drives ok 3rd 4th 5th 6th, but 1st and 2nn the pedal can stick. You have to pull the pedal up to get a gear. Put LUK parts in???? Bit rattley when it first stats up sound like the fly wheel is going again. 2nd fly wheel in under 400 miles. £800 spent and no better off. PLEASE HELP IF YOU CAN???
    WGAF#5
    moved to engine and drivetrain - hopefully people will then see the thread and be able to help
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Clutch problem
    By guvnagra in forum Engine & Drivetrain
    Last Post: 30th September 2011, 11:49
  3. Sticking clutch pedal
    By pricey in forum Engine & Drivetrain
    Last Post: 16th January 2011, 21:22
  4. 2.2 sri clutch problem help!!
    By jamieclayton9 in forum Engine & Drivetrain
    Last Post: 21st January 2009, 20:48
