Results 1 to 10 of 15
Thread: Urgent help with 2.0t .....I'm under it now
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Default Urgent help with 2.0t .....I'm under it now
    Does anyone know how to release the tension on the tensioner so I can remove the drive belt? The bolt where it goes on to the block don't do it. Is it the one where the jockey wheel is?
    Engine : 1.9 CDTi
    The 15mm bolt that goes through the pully needs to have a spanner on it and try to 'tighten' it (It wont undo it but compress the spring in the tensioner) and it should release the tension as it swings away.
    Apr 2008
    suffolk
    So I need to do it as if I'm tighteneing it up?!
    Engine : 1.9 CDTi
    Yes.....
    It wont tighten, all it should do is 'swing up' and release the tension.
    Apr 2008
    suffolk
    Well it ain't happening I'm tightening it be not releasing could tensioner be seized
    Engine : 1.9 CDTi
    Any chance of a picture of the pullys?
    Regular Member Jezzy's Avatar
    S.E
    I don't think you're supposed to "tighten" it to remove the tension. According to Haynes, you should use a Saab special tool that goes in the square hole on the pulley arm, or in the absence of this tool Haynes fabricate their own - they put a bolt through a flat bit of metal and the bolt then goes into the hole near the right hand end of the tensioner-pulley arm, (near the centre of the tensioner-pulley itself). Another bolt goes through the flat bit of metal and engahes with the top of the tensioner arm, so that when you turn the flat bit of metal anti-clockwise, the tensioner arm gets rotated as well.
    Alternatively, see if the square end of a ratchet will fit in the square hole and see if you can make the tensioner lift up if you turn the ratchet anti-clockwise.
    S.E
    Quote Originally Posted by lee gsi View Post
    It's here, in the pic of the side of the engine on it's own (the 1st pic)
    http://www.vectra-c.com/forum/showthread.php?t=101304
    swansea
    When I did my 2.2, which looks the same, I put the handle end of a ratchet underneath and pushed upwards, from a lying on the floor position. It wasn't as easy as people make out . Wear a glove to take some pressure off your palm. Think in the end I used a car jack to hold the ratchet in position when arranging the belt.
    stockport
    Thumbs up
    Christ!!,you don't f**k around when it comes to doing thing properly do you?. FELIXX.
  1. Need urgent help
    By cbetts2005 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 01:07
  2. Urgent help!
    By Kieran1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2009, 19:17
  3. urgent
    By jones20002uk in forum Engine & Drivetrain
    Last Post: 21st April 2008, 17:10
  4. Urgent help please
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:46
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
