Thread: Wind screen blower
    Kingston Upon Hull
    Default Wind screen blower
    Hi All a mate of mine has a Vectra c 1.8 petrol and has asked me to ask you if you know what will be causing this fault
    The blower only works on number 4 on the switch and how do you repair the problem
    Thankyou
    Jacko
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    need a new heater resistor pack thing, you can either solder a new resistor onto the one already there or buy a new unit, bout £20 on ebay
    No idea what the resistor type is tho sorry, its on here somewhere
    Aug 2010
    York
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    rs32a you get it from maplin 79 pence
    Aug 2010
    York
    Quote Originally Posted by markj23 View Post
    Cheers bud, was bugging me then
    Aug 2009
    sheffield
    hi,just done this repair ( heater fan only working on speed 4 )just renewed the fuse ,its a =240deg c thermal fuse. part number from maplin,s RA23 price 82p on 15/1/11. DO NOT SOLDER strip a electrical block and use this ,or crimp.as it gets very hot.
    Belfat (NI)
    If you look at your swind screen the plastic strip is up abit. Water is letting in to your foot well. Need to fix that and change your resistor.
    stockport
    Arrow
    That's the thermal fuse number.You can fit this across the terminals with a chop block,(cut the plastic outer off first though),and job done. FELIXX.
    Kingston Upon Hull
    Thanks for the info can i ask were is the fuse on the car and how do you get to it
    Jacko
    Feb 2011
    Kent
    I had this problem,fan only worked on 4 or demist mode,this superb site saved a few hundred quid.... bought resistor unit GM# 9180020 £31. 5 star screws, glove box out and top right,there it is! a little wiggle and hey presto..... fans working again!!!!! Some one put pics on here,my hero cheers fella!!!!
  1. Half screen to full screen,
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 01:13
  2. new screen now screen wiper problem
    By kenno31 in forum Bodywork & Interior
    Last Post: 18th February 2012, 12:34
  3. To deflect wind, Or not Deflect wind; That is the question
    By anthonychall in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 00:08
