Thread: Heated Seats wiring question
    Jun 2009
    Chelmsford
    Default Heated Seats wiring question
    Just fitted new leather interior from an elite into my SRi, along with heater switches for seats, but cannot find the wiring anywhere to plug the switches into. Any idea where i could find it also do i need to fit a fuse or relay or should it just plug and go or is it a bit more complex??
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    Dunstable
    I know that Fuses 15 & 16 in the boot are for the left and right front heated seats. They're 15amp fuses. The plugs under the seat that you should've unplugged when you changed the interior over should include the wiring for the heater elements. Wether or not you've got the wiring in place though I'm not sure. Someone else can advise you on that
    Jun 2009
    Chelmsford
    I thought that i would find the wiring for the heated seat switches behind the blank covers that i took off to fit the heated seat switches, took the glovebox out but couldnt find any wiring, do i need to take out the radio to see if anything is taped up behind it??
    Car is a 05 CDTi SRi 150.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have the same car/year and there was no wiring for the heated seat switches. Might only be there on the facelift
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    If you remove the the two blanking covers in the dash and look towards the back of them, if you can see the connectors in the back then the wiring to the BCM is there, if not you're in for a world of pain. You would need to add the wires from the BCM to the switches, not fun, as you have to remove most of the dash.
    Depending on age/spec of your car you may need to add the wiring from each driver/passenger footwell to the connector under each seat.
    Hope this helps.
    Dunstable
    Had the plugs behind the blanks on both my preface and facelift. If you pull the blank out and see a plug at the back then you have the wiring for the switches and they will go straight in.
  1. Wiring heated leather seats
    By Chewy72 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2012, 23:29
  2. Heated Seats Wiring
    By OilBurner in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 20:41
  3. Rear heated seats wiring
    By Piston broke in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2010, 10:18
  4. Wiring heated seats
    By Steve-E in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2010, 13:52
  5. Seat wiring looms for heated seats
    By OilBurner in forum Parts for sale
    Last Post: 13th February 2007, 10:25
