Thread: Rear centre seatbelt
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default Rear centre seatbelt
    About to set off this morning with a full car on a 550 mile round trip when the Rear centre seatbelt would not budge.
    Was not too happy about having an unrestrained passenger but we had no option but to set off.
    1st stop we looked everywhere in case the was some kind of lock or something keeping in place but nothing. Folded the chair forward which gave it some slack but still no budging - is there something i'm missing? Any ideas to sort if its broken?
    I thought the roads in Cornwall were bad but those around Bicester and Oxford are horrendous. Went over a pot hole and thought the wheel had been ripped off the noise it made.
    Car also gave violent juddering in cruise control a couple of times - anyone else had this?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Fold seat forward then slam it as hard as you can back sometimes they don't pull out until seat is positioned correctly and secure
    Irmscher Insignia CDTI 130
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    cheers, i'll give it a go
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    I had the same problem about a year ago. With mine I found the seat not fully engaged/locked as bigmac says. I think there must be a safety feature that will not let the seatbelt be used with an insecure seat.
    When it did it to me I had visions of me dismantling the seat to have as look so was relieved when I worked it out!!
    wales
    had the same problem with mine wouldnt budge even after slaming it back in . caused my car to fail mot on seat belt mot tester said common fault on vectra. took the belt out and anchor point and just passed mot with advisory not to botherd about seat belt as its a work car and only me init but mot tester said it should have 1 fitted by next mot so i have been to scrap yard and trying to find a rear seat with same trim code and working belt
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    It's easy to change the belt, it's 3 bolts iirc as I sold the one out if my spare rear seat
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Quote Originally Posted by holtie View Post
    My seat is fully engaged but no budging, in fact i struggle to get my oath fingers behind the belt
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Quote Originally Posted by bigmac View Post
    Do you take the rear seat apart then as I cant see how to remove it?
    Jun 2009
    Whitburn
    Once you have the belt mechanism out if you pop off the cover on the side that had the cable connected to it you will see a ball bearing and small lever. This is the mechanism to stop the belt coming out if the seat back isn't fully home. Simply remove the ball bearing and lever, replace the cover and it now works. Just make sure that the seat back is fully home before you let any one use the centre seatbelt.
  1. Rear centre seatbelt problem
    By wright8672 in forum Bodywork & Interior
    Last Post: 1st February 2013, 14:27
  2. centre rear seatbelt
    By Edd in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 17:13
  3. Extending Centre Rear Seatbelt
    By philtr in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2009, 10:45
  4. Rear Centre Seatbelt
    By marchmont51 in forum Bodywork & Interior
    Last Post: 26th February 2007, 13:35
opel vectra c rear seat belt
how to change rear centre seat belt vectra c
vauxhall vectra rear middle seat belt
where does rear centre seat belt fit on vauxhall insignia
vauxhall zafira middle seat removal
opel vectra beck seat belts
vectra c rear seat belts different
vauxhall vivaro centre seat belt
how to change middle seat belt vectra c
vectra c rear center seatbelt
vectra c rear centre seat belt removal
how to remove middle rear seat belt vectra c
