Thread: mot advisory offside inner steering rack joint has slight play
    Dec 2010
    wigan
    Default mot advisory offside inner steering rack joint has slight play
    offside inner steering rack joint has slight play any one no what part i need to get to fix this probelm
    prestatyn
    you need inner tie rod bars,might as well replace them both around £15 to £20 each probaly cheaper on ebay,you might as well change track rod ends,then get the tracking done they can be a pain to undo i use stilsons,make sure to replace gator clips i used cable ties but probaly best getting clips only cheap
    Dec 2010
    wigan
    thanks
    Dec 2010
    wigan
    is a outer tie rod a track rod end and to fix the mot advisory for the inner steering rack joint would i just need to change the inner tie rods thanks
    VIP-Member puppet's Avatar
    East Ayrshire
    9 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I used one of these to do mine a few months back :
    http://cgi.ebay.co.uk/Laser-1144-Vis...item2a0a2bda50
    Was pretty much ideal for the job, as one end fitted the old tie rods ends (36mm), and the opposite end fitted the replacements (32mm). Not sure why they were different, but worked a treat anyway.
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Going to attempt this later, the kit came with two black rubber bands, any idea where they go?
    East Ayrshire
    9 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    You'll need some ty-wraps for the rubber gaiters, but as for rubber bands, nope, no idea.
    Jan 2010
    Cornwall
    Sorted, they go onto the steering rack where the gaitor sits, not sure what the sachets of grease were for as the balljoint was already greased, maybe for greasing the bands to allow the gaitor to go on easily?
  1. Help Steering Rack Universal Joint....
    By mucklestone in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2016, 13:33
  2. MOT advisory... Play in steering rack joints
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 21:43
  3. Offside track rod end ball joint has slight play
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 19:08
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. steering rack play, maybe?
    By iasha in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2011, 21:28
vectra c steering rack inner joint
zafira steering rack inner joint
play in steering rack inner joint corsa
vectra steering rack inner joint
astra g play in steering rack inner joint
corsa steering rack inner joint
vauxhall corsa steering rack inner joint
vectra c inner tie rod removal
slight play in steering rack inner joint
slight play in steering rack end joints
corsa mot 005 play in steering rack
slight play steering rack knuckle
vauxhall zafira steering rack joint movement MOT
inner rack joint
slight play in nearside steering rack
vectra b front inner rack
play in inner steering rack joint
play in steering rack inner joints zafira
play in steering rack inner joint vauxhall astra
slight play in both inner rack joints
Slight play in power steering rack corsa
vectra oil by inner steering jointvectra c slight play in steering
