Thread: Handbrake Issue
    Jul 2009
    UK
    Default Handbrake Issue
    Can you tighten the Handbrake in a 57 / 08 Vectra yourself, i seem to have a bit of Travel in mine. if not what type of cost will it be to rectify it?
    Benners
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Hi mate i had the same prob when it came to the mot in dec with to much travel i work for gilders so i have a full team off tec,s and we found that they adjust them self and i spoke to vauxhall about it and they told me if there is to much travel its either the rear pads are worn and ready for new ones or a streched hand brake cable but trust me mate u cannot adjust them i put new pads in my,n and it worked a treat i still have a bit to much travel not as bad as it was but it needs a new cable and that will sort it but it past mot so ive not bothered mate
    try new pads and bleed the system up as when u put the break,s on the rear pads clamp to the disks then u appy the hand break which locks it on so if u do change the pads make sure u pump the breaks and bleed the system then when u have appy the breaks then pull the hand break on and off a few times well about 20 times but keep ya foot flat down on the break peddle while doing it and it should be tighter if not new cable time if u did both u will be fine £10 rear pads and £15 for new cable and it comes as a kit
    sorry for going on just hard to exsplain
    Jul 2009
    UK
    How much labour cost would be involved? any idea?
    Gävle, Sweden
    I replaced rear discs and pads today, hard to get the hand break wire back into place. Would it be easier to do it if I ask someone to put pressure on the break pedal when I'm pulling the wire into place?
    Gävle, Sweden
    A clarification: my hand break will be too tight if I force the wire into place, can someone explain to me how to reset the handbreak?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    what cable have you taken off? you dont have to remove any cable just wind back the caliper
    Gävle, Sweden
    I know, but the piston was fully extended and I just couldn't rewind it with it mounted, so I removed the caplier to be able to put some more power with the pliers. (The piston was really stuck!)
    So here I am with a loose hand break cable...
    Aug 2010
    Luton
    Quote Originally Posted by stryker99 View Post
    did you force it back? its a rewind only I see you say rewind but was just making sure, I would remove caliper and pads reconnect cable rewind piston and refit then try to adjust handbrake in normal way : pump pedal till hard then with finger on button pull lever a few times to take the slack
    Regular Member tammyman09's Avatar
    tamworth
    I took my centre arm rest out and the whole caboodle like drinks holder aswell. i found underneath that theres a white plastic thing and a huge spring with a rod through it that you can wind up. i wound it up and hey presto it tightened it. also the self adjust mec switch looked like it had been disconnected on mine...probably vauxhall after they did my clutch!!!
  1. Signum handbrake issue
    By Desolation91 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2013, 23:00
  2. Handbrake issue
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2010, 23:25
  3. Vauxhall Handbrake Issue on BBC1 now
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2007, 15:48
  4. handbrake issue??????
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2007, 10:33
