Results 1 to 10 of 15
Thread: exhaust fumes in car
    Oct 2010
    TELFORD
    Default exhaust fumes in car
    Hi all, Can anyone help me? ive got 1.9 cdti 120, and recently been experiencing exhaust fumes in my car on start up, not while driving though, ive jacked it up today to check the exhaust itself but could not find anything unusual there, but on further examination ive noticed alot of black crap over and around the DPF, although i can not see any visual cracks in the solid/flexi pipes either end of DPF, there is a lot of black crap on a rubber coolant pipe (front of engine, into DPF). Any help is appreciated?????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could it be a split Turbo pipe?
    Oct 2010
    TELFORD
    Thank you for your prompt reply, i intend to have another look tomorrow at the turbo, i did have a swift look earlier on but couldnt see too much, can i run the car without the big black rubber hose, the one to the inlet manifold? it hampers the view of where the black soot is. thanks yet again
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I dont think you can run the car without the hose but I think it could be the hose that is leaking. If you take the hose off and check it you can also see where the black soot is
    Oct 2010
    TELFORD
    cheers again matey, ill give it a coat of looking at on the morra, it sounds pants at the minute1
    Are there any meets planned in the midlands any time soon?
    PRESTON
    Possibly the egr cooler leaking exhaust gas or maybe the engine breather pipe split where it joins the engine at the back. See if you can post up some pics of the area affected, it's easier to help if we can see it too.
    Oct 2010
    TELFORD
    Will do barney, thank you for your in put.
    PRESTON
    No problems wally. i have a 120 and had similar smells comming into the car when i first got her. It turned out to be a loose clamp on the egr cooler (tubular thing under the thermostat) allowing exhaust gas to escape into the engine bay, then into the heater vents. Like you, it could only be smelled when the car wasn't moving, as airflow disperesses it. Good luck.
    Oct 2010
    TELFORD
    Hi again, i have found the leak.... I think, it looks like its the joint of the rigid/flexi pipe from the exhaust manifold to the front of the DPF, i am going to try and nip the clamp up tomorrow in the light. Thanks for your help guys.
    Oct 2010
    TELFORD
    My apologies, I have had an embarrasing moment with regards to my exhaust problem. I was told by by a work colleague that the pipe that was blowing on my car was from the exhaust manifold to the DPF...... i spent 10 mins of my life telling a parts bloke from local VX dealer that i need the above pipe only to be told that its the pipe to the EGR cooler that i need, FUM DUCKER. i am going to hand a few slaps to my big colleague tommorrow, they did say that i would have to purchase the whole cooler and pipes, is this right or can i get just the pipe from a autofactors??
  1. smell of exhaust fumes
    By murfcitygent in forum Engine & Drivetrain
    Last Post: 18th October 2016, 18:59
  2. exhaust fumes in cabin
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 07:33
  3. Exhaust fumes in cabin
    By Nicolas in forum Engine & Drivetrain
    Last Post: 18th January 2011, 08:18
  4. exhaust fumes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2009, 14:44
  5. Engine/exhaust fumes in me car!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 22nd February 2009, 23:02
Vectra c exhaust fumes in car
exhaust fumes in car vectra c
exhaust fumes in car when you start it up on a vauxhall vector
vauxhall vectra smell of exhaust fumes
08 vectra 1.9 cdti diesel fumes in car
vauxhall vectra 2006 1.9 cdti exhaust fumes on start up
vectra c petrol fumes inside car
Vauxhall vectra b fumes in car
vauxhall vectra exhaust fumes in car
vectra 1.9 cdti exhaust fumes in car
