Results 1 to 10 of 11
Thread: squeaky fan
    Nov 2010
    LEIGH
    Default squeaky fan
    about a week ago my fan in the car started to squeak wne on the lowest level. tonight the fan is very intermittent!
    is this the dreaded blocked blower or just a goosed blower?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like you may have water coming in through the pollen filter. Is the passenger side floor wet? Get some wd40 onto the spindle of the fan before it rusts up any more
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    Quote Originally Posted by John IS3 View Post
    does wd40 work?
    and how long does it last
    11 Post(s)
    No, wd40 is only a temp fix.
    Use some proper oil on it.
    Feb 2011
    Selby
    Ideally take the fan housing off and take the motor out so you can get to the bottom bearing properly.
    Mine was squeaking and it actually turned out to be that the fan was rubbing on the motor casing. No amount of WD40 or grease would fix that, but a couple of taps with a hammer to move it up the shaft did...
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by vectra ste View Post
    does wd40 work?
    On my old 2.0T WD40 did the trick, and was still working 2 years later when I traded the car in. Problem had been caused by water ingress (blocked drain) before I bought the car.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by john_k_sri View Post
    thanks to you all for your replys
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    myn has been doing the same im looking to take the motor fan out as ive tryed wd40 spray grease and its still doing it but not got a clue how to remove it look on the how 2 section and could find nothing only resistor fix
    Dec 2010
    Cumbria
    Take the pollen filter out and look down. You can see the yop of the fan. Use Silicon grease instead od WD40.
    I did it last week and not heard a squeek since!
    Just beware when you turn the fans on...as the gathered spray will be blown out of your vents!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by 0114NIGEL0114 View Post
    this may help you im thinking of taking it a part
    http://www.vectra-c.com/forum/showth...ghlight=heater
  1. Squeaky Turbo?
    By british_bulldog in forum Engine & Drivetrain
    Last Post: 4th July 2010, 17:05
  2. What causes Squeaky Brakes (Vec-B)
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 09:47
  3. Squeaky rear end!
    Last Post: 18th October 2008, 01:46
  4. Squeaky Door...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 21:53
  5. Squeaky belt
    By Marc 100 in forum Engine & Drivetrain
    Last Post: 12th December 2006, 21:28
vectra c squeaky fan
vectra c squeaky heater fan
vectra heater fan sweak
vauxhall vectra c fan squeaking
squeaky fan vectra
squeaky heater fan vectra c
Vectra how do I stop a squealing heater fan
blower fan squeaking on vectra
Vectra blower squeaking how do I fix it
vauxhall signum squeaky blow fan
squeaky fan on a 2006 vectra
vectra c squeaky heater van
why dose my vectra c fan squeek
squeaky fan vauxhall vectra
vauxhall vectra squeaky heater fan
how to stop squeaky fan vauxhall vectra
squeaky fan blower vectra c
vectra c squeaking fan
vectra c fan squeak
vauxhall vectra squeeky fan
