Thread: What could possibly go wrong?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default What could possibly go wrong?
    Nice simple job tomorrow - changing the rear brake discs and pads + changing the fluid. Should be simple but very few things seem to be on the signum...
    I think I am fully prepared, with the following items:
    Discs+Pads
    Caliper winding-in tool
    Full set of Torx sockets plus ordinary sockets and spanners
    Easy-bleed kit
    2 ltrs DOT4 brake fluid
    Copper grease
    Have I forgotten anything? Are there any pitfalls that I should be aware of?
    Cheers!
    Regular Member RobW's Avatar
    Tain - Easter Ross
    I ALWAYS manage to bend the retaining clip out of shape and can never get it back to how it should be.
    Get a pair of fine nosed pliers, you'll need them to wind the piston back when you get tired of using the re-wind tool.
    Regular Member Jezzy's Avatar
    S.E
    Pump or electric inflator for adjusting the pressure in the spare tyre for powering the Eazi-bleed kit.
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Mileage : 101000
    Excellent, thanks guys. I have those items so should be ok then!
    I never had any difficulty winding in the calipers on the Astra, I've guessing these will be similar?
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Mileage : 101000
    It all went rather well - a bit time consuming and hands got rather cold due to the chilly breeze outside, plus had some difficulting undoing the bolts that retain the inner part of the caliper to the hub but got there eventually!
    Only remaining job is to adjust the hadbrake. Is there a howto on this? If not, where is the adjuster and how do I get to it?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by littleteapot View Post
    just pull it up and down a few times with thumb on button it resets its self
    them bolts are tight arn't they
    Mileage : 000
    When you put the pads in. You must press the FOOT brake first. To take up all the play. If you pull the HAND brake first. You will run out of handbrake adjustment. As far as I am aware there is no adjustment on the handbrake. Though I will stand being corrected.
    Aug 2010
    Luton
    Quote Originally Posted by ed taylor View Post
    I assumed the play was taken up as he had bled the brakes but yes your right
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by markj23 View Post
    I bled them using the pressurised easy-bleed, and then repeatedly pressed the pedal until all the free play was taken up and the pedal became firm.
    The handbrake had been off the whole time.
    As per Ed Taylor's post above, I have tried operating the handbrake repeatedly with the button pushed in but it makes no difference. However, it still goes up a long way before having any effect (about 8 notches). This is not a new problem - had been gradually getting worse over the past year or so anyway.
    So are we saying there is no manual adjustment screw on these? It's a 2004 Signum 1.9cdti. If so, then what else could be causing this issue?
    Aug 2010
    Luton
    no there auto adjust have you had the recall done at the stealers?
  1. egr possibly?
    By gav_embo in forum Diesel Engine related
    Last Post: 4th October 2009, 20:57
  2. Wrong place wrong time.
    By silverhairedracer in forum General Chat
    Last Post: 29th October 2008, 14:20
  3. Possibly a new car for me ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 20:30
