Results 1 to 10 of 11
Thread: Strut top bearing changed but now pulls to right
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Strut top bearing changed but now pulls to right
    Hi guys as title my strut top bearing had gone and was making a Lou twang everytime I turned the wheel. Ichanged the strut top bearing tonight took me 40mins start to finish nit bad really and te part was 21.20 Inc vat from Vauxhall but trade club does not work on that item only service items I was told today at Vauxhall
    Put all back together again and the car now seems to pull to the right it was fine before I changed it. but just taking out the strut surely can't change anything it's only 2bokts through the hub and 3 holds the top into the wing
    Any ideas guys
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Anything to do with suspension needs tracking afterWards
    Irmscher Insignia CDTI 130
    kings lynn, norfolk
    I see I am replacing the other side next month when I get spare cash so will it be ok to drive it's not pulling bad just slightly and then once other side is changed end of next month then I will get tracking done
    Will this cause any side effects driving for a few weeks
    Nov 2010
    MIDLANDS
    might just cause a little uneven tyre wear
    Quote Originally Posted by winnie2457 View Post
    Four weeks of wear on a tyre should be minimal, but once worn that pattern will accelerate through the remaining life of that tyre
    Therefore in two weeks time swap both front tyres
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    is it possible it could be pulling because you have only changed the one? If the other side is worn it may be working against the new one causing it to pull. Just an option..
    Quote Originally Posted by lee1828 View Post
    Yes, hence why the OP is going to be replacing the other in four weeks
    Usual process is to replace both at the same time, if one side has worn the other side won't be far behind
    Equally, it may have little or no play, but compared to a new one it will have some movement
    Jan 2010
    stockton on tees
    He was replacing the other one in order to then get the tracking checked, hence why i gave another opinion what may be the cause. I will not affect his tracking by removing the front struts. My point was, if he replaces the other side then the pulling may stop, if his front tyres wernt showing any signs of uneven wear before replacing the other bearing and changing the opposite side cures the pulling, that would save him paying out for a tracking check.
    kings lynn, norfolk
    Cheers lee I will e replacin te other one next week hopefully I get paid on mon so probs do it next weekend
    I didn't think removing tr shock would
    Change anything on the tracking side and I have 4 new tyres fitted 3 days ago too car drove fine before but once changed now pulls tonthe right
    But the other side is creaking too
    Now so I will change that if all is fine then I will leave it if not I will have to get tracking done but hopefully other side will solve it fingers crossed
    Jan 2010
    stockton on tees
    no probs mate, i think the other side will be the issue. You will probably find replacing it other will cure it. Good luck mate..
  1. Top strut bearing help/advice
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 17:50
  2. Not another strut bearing thread...
    By parsco in forum Handling & Braking
    Last Post: 15th February 2010, 13:55
  3. Wheel bearing sound, but all have been changed!!!!!
    By FosterBoss in forum Suspension, Wheels & Brakes
    Last Post: 25th November 2009, 21:27
  4. strut bearing
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 09:50
  5. strut top bearing?
    Last Post: 10th September 2009, 19:55
