Thread: need help vectra c 1.8 replacing steering transponder
    Jul 2010
    pencoed
    Default need help vectra c 1.8 replacing steering transponder
    Hi all
    i'm looking for someone to remove and fit a transponder to my vectra c18 ls.
    without the need to go to the steelers can anyone help based in south wales
    Bridgend area
    Regular Member benny's Avatar
    Feb 2006
    dudley
    what are you replaceing ? ..
    Jul 2010
    pencoed
    Default help
    Hi Thanks for the question
    sorry for being late working 12hrs
    i have had to drill out my lock due to my steering lock stuck on and unable to get cowling off or turn the key to remove the barrel
    i have now succeeded in wrecking the barrel area of the steering column controls.
    i have managed to get a ebay part with the same part numbers.
    i was thinking if i remove my key chip reader from my steering controls and fitted it along with a replacement barrel from vxh matched to my key.
    would it work [it sounds sensible ] however i don't want to cause anymore damage and need someone other than the steelers to help sort me out more than willing to pay but not steelers prices per hour
    Cheers in advance
    Ps please no telling me what i could have done before getting to this state i know i f~~ed up
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    The transponder bit i believe is built into the CIM unit which goes around the steering column (its a black ECU which the indicator stalks plug into)
  1. How to remove transponder on new vectra key?
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2012, 20:07
  2. Vectra c transponder problem help needed!!!!
    By Danielson16 in forum Engine & Drivetrain
    Last Post: 17th February 2011, 07:47
  3. Steering light on after replacing inner joints
    By peterman63 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2010, 18:38
  4. Vectra C Transponder ?
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 01:02
  5. Replacing a steering wheel
    By Karl in forum Bodywork & Interior
    Last Post: 8th July 2008, 18:27
2007 VECTRA PROBLEM REPLACING STEERING CIM
replacing steer vectra c
