Results 1 to 10 of 17
Thread: Not a happy chappie
    Sunderland
    Angry Not a happy chappie
    Can someone tell my vectra c 1.8 that if new parts get fitted it should run better NOT WORSE!!!!!!!!
    had a fault code for first lambda sensor,replaced it,then found that the egr valve was sucking in air,so replaced that
    Now getting fault codes for the maf sensor and the car is worse then first started but not using loads of petrol but stuttering at acceleration.ordered maf sensor today and I'll see what happens next.
    Flaming sensors!!!!!!!!!
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Quote Originally Posted by wilson002 View Post
    Maybe its running worse cause the sensors are playing havoc with on board computer, sounds like a nightmare!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Dont tell me ,you went to a vx main stealer
    and still loving it
    Northampton
    Engine : A20DTH
    Mileage : 88000
    MAF should sort it (as long as its not a cheap one!), I think I would have done that first as it does cause the other sensors to throw an error up when its not working. When the maf is failing it can cause over fueling which burns out the other sensors
    Sunderland
    Can I disconnect the maf and use it to see if it is that causing the problem
    north east
    ^^ yes, if worse = not maf if better = MAF, but you will be in limp mode so cant go over 3000 rpm
    Sunderland
    Update,just put in new maf sensor I've just bought,cleared the fault codes using OP-COM,went to work(4 mile drive) and it was stuttering on acceleration!Dont believe it!So I've disconnected the lead to the maf sensor on the way home and it was fine(so sending the sensor back)
    any more advice guys!!!!at my wits end here!!!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could it be the coil pack? the best way to try and sort it to changes the parts with another 1.8. I know this is not always possible. Was it a VX maf or a cheap copy?
    Sunderland
    Vaux maf m8
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    You said you disconnected the maf sensor lead and it was fine.
    Must have been a duff new maff sensor. Try another one.
  1. Happy Chappie re MPG!
    By Signum7060 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 05:22
  2. Full Hunter alignment - One very happy member and one not so happy
    Last Post: 14th April 2012, 14:08
  3. Happy Man.....
    By scotty84 in forum Styling
    Last Post: 29th September 2011, 20:16
  4. Another happy chappie
    By Middo in forum Insurance Chat
    Last Post: 2nd July 2009, 14:17
  5. I'm happy..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:47
