Thread: Door replacement
    Oct 2009
    Belfast
    Default Door replacement
    Does anyone have instructions for complete replacement of drivers door? I had a dvd thing that you can print out step by step instructions but can't fing the disc.......
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Its just a case of undoing the two small torx bolts on the hinges(on the A pillar) and disconnecting the multi plug for the electrics. You need to change the module on the door, behind the door card, and dont forget to swap over the outer lock part of the handle.
    Full Member paul.sessions's Avatar
    leighton buzzard
    undo the door strap too. but get someone to help you i scratched the side of my car tyring to put it back on, on my own
    DERBY
    you will have to adjust it to fit your car, gap and levelness or it will look pants
    Oct 2009
    Belfast
    Quote Originally Posted by sharper View Post
    Well the door is on - but I have a couple of questions - as pointed out above I need to adjust the door - but how do you do it - is it just the bolts that hold the hinge on the door? - How do I raise the back end of the door and mover the botom in slightly at the front? I haven't had time to try yet as the door took so long.
    Also, how do you replace the rubber alond the top of the door - ther is a screw at the mirror end, but how do you remove the rubber neatly - slide or pull?
  1. PDR or a replacement door?
    By John LE in forum Bodywork & Interior
    Last Post: 5th February 2013, 01:08
  2. Cost of a replacement door?
    By 1ctchris in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2011, 03:36
  3. Full door replacement- Help please
    By 123rado in forum Bodywork & Interior
    Last Post: 27th July 2010, 18:50
  4. Door Speaker Replacement Easy?
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 23:05
  5. Door strap replacement
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 18:08
