Results 1 to 10 of 11
Thread: HELP!!! oil pump
    Nov 2010
    Lincoln
    Default HELP!!! oil pump
    Its becoming a really long story... basically i snapped an alternator pully. The mechanic i use put a new one on but used a bolt that was a few mm to long. This sheared off and smashed the oil pump. New oil pump needed!
    This is nearly 6weeks ago. NO CAR! I've been waiting on this part for 5 of those weeks! Can anyone help? The part number is 55215401. Its a 150 diesel 1.9 lump. Main dealers cant get hold of them, whats going on?
    Please help guys!
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Remember that its a Fiat engine so you could try Fiat for one and see if they have any in stock.
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Maybe some could advise if this is the right pump too.
    http://cgi.ebay.co.uk/Saab-9-3-9-5-O...5#ht_765wt_932
    PRESTON
    Part number 55198355 in Ebay is only listed on Vauxhall EPC for Z191DTL and Z19DT engines. The correct pump for the Z191DTH is 55215401, so i doubt the Ebay one is correct, even though it is a very good price.
    Maybe try your local motor factors and ask them to try a cross reference on part number 55215401. They use a program called Techdoc, which will show them if there are other manufacturers of pump and if so,they might be able to get you one.
    Oct 2009
    Luton
    I can check the GM PN & Fiat PN for you tomorrow & see what the stock levels are at the warehouses
    Oct 2009
    Luton
    The PN 55215401 is correct. There is no stock in the UK but there are 2 here in Germany - ask your dealer to order it 'no stocked'.
    The fiat PN is the same PN for their JTD version.
    PRESTON
    Quote Originally Posted by I cdti View Post
    Surely the dealer would have checked for non stock on Channel21 locator, just goes to show, another dealer who doesn't know there stuff. Well done for finding the pump for Awkward Kid.
    Do you work for Opel in Gemany I cdti?
    Oct 2009
    Luton
    Yes I'm a engineer in ITDC
    Nov 2010
    Lincoln
    Cheers for the help boys! One turned up on Saturday after 4wks of back order. I did find out in the meantime that the 1.7 lump oil pump should work. Apparently the 1.7 lumps are bored out to 1.9, so share a lot of parts.
    Again thanks for the help
    Oct 2009
    Luton
    Glad you are sorted, but who told you the 1.7 & 1.9 are the same???
    The 1.7 & 1.9 are different designs, the 1.7 is Isuzu, the 1.9 is Fiat.
  1. 2.2 Pump and Reg.....
    By shankton in forum Engine & Drivetrain
    Last Post: 12th January 2012, 18:05
  2. away to pump 500L of heating oil with a 3.99 ebay drill pump.
    By TimTay in forum The 'Off Topic' room
    Last Post: 19th September 2011, 22:09
  3. AIR CON pump
    By alijlacy in forum Engine & Drivetrain
    Last Post: 9th January 2011, 21:33
  4. which pump?
    By keith1983 in forum General Chat
    Last Post: 25th April 2009, 20:35
