Thread: Wheel Arch Inner Liner.How Are They Fixed ?
    Jun 2009
    Middlesex
    Default Wheel Arch Inner Liner.How Are They Fixed ?
    I need to remove r/h inner wheel arch liner to gain access to power steering reservoir.How are they held in ? I guess they are plastic type fixings which i will have to replace.Can i only get these from VX.
    Dobs.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It would be just as easy to remove the front bumper mate. that way you'd get better access
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Dobs View Post
    Dobs.
    The plastic clips things are about 22p each from the dealer and you can buy individually.
    Gazza4
    Jun 2009
    Middlesex
    Any idea how many i need as i will buy them in advance before removing lining.
    Dobs.
    11 Post(s)
    You can re-use them providing you can find the peg that pushes through the middle to spread the locking clips. Just push it out and then remove the clips.
    They look something like this
    Regular Member rosssri's Avatar
    S.Lanarkshire
    I managed to rip off a front mud flap by reversing over a stone on rough ground at work which I'd fitted with 5 self tapper screws which also pulled out the inner plastic wheel arch liner. Anyway I've since refitted mud flap & raised them up by about half an inch so they can't catch anything again.
    Since I've refitted the drivers side flap I'm very occasionally getting a clunking noise.
    It sounds as if the inner plastic linings maybe moving about - would this be a possibility?
    I had to use 3 of the clips pictured above to refit wheel arch lining.
    I did notice there was 1 hole inside the wheel arch (at the very top) where the hole wasnt lined up properly & I couldn't get a new clip in to secure it. Could this be causing the noise?
    S.Lanarkshire
    Ment to add. The front wheel arch lining is secured by 2 screws (Torx T20 heads on them) at the front of the wheel arch. These are easy to find & also about 4 or 5 of the plastic rivet clips in picture above.
    S.Lanarkshire
    There's 6 of these clips in the drivers side wheel arch.
  1. sri arch liner
    By alan15153 in forum Bodywork & Interior
    Last Post: 17th May 2012, 13:48
  2. Wheel arch liner clips?
    By macdad in forum Bodywork & Interior
    Last Post: 1st June 2011, 23:03
  3. Have i part of my arch liner missing?
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 12:12
  4. Front wheel arch liner
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2008, 08:50
  5. Removal of plastic wheel arch liner
    By spatch in forum Bodywork & Interior
    Last Post: 4th September 2008, 09:49
how to remove vectra c inner wheel arch cover
wheel arch liner removal
corsa vxr wheel arch liner
removing wheel arch cover on 2006 astra sri
astra G inner wheel arch
how do you remove plastic clips from inner wheel arch
astra j wheel arch liner
how to remove rear arch liner vectra c
how to remove a vauxhall vectra wheel arch lining
how to remove the wheel arch lining on a vectra c
how to remove the plastic wheel liner from vauxhall corsa
remove the plastic from inside a corsa wheel arch
zafira wheel arch fatener
vectra wheel arch liner removal
how to remove rear inner wheel arch on vectra c
vauxhall vectra wheel arch trim screw
removing a Vectra C wheel liner
remove wheel arch cover
vectra c removing arch liner
corsa c front wheel arch fittings
vectra c remove inner wing
vauxhall astra wheel arch liner
vectra c wheel arch clips
astra j wheel arch liner fixing
vauxhall vetra inner wheel arch screws
