Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: real problems help!!!!
    kent
    Default real problems help!!!!
    ok so i have a vec 2.2sri apparently with the z22se engine
    the 1st problem is that recently after about 15 miles the car dropped revs lost power then went into high revs 5k with no foot on the accelerator, there was a yellow light on in the dash board turned the engine off and restarted car engine ok back to full power just with light on
    followibg day no light and car ok untl wham it did it all again so off to vauxhall who put it onto the computer which stated no error codes but suggested maybe fuel pump and regulator ay £700 ouch
    has anyone else had this problem i would of thought if the pump etc had gone there would be codes on the fauly computer
    i would appreciate any help or advice
    Full Member gibbon7000's Avatar
    lincs
    The 2.2's are renowned for their fuel pumps problems. Altho for £700 i'd want an excact diagnosis before parting with my cash.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    kent
    what happens if they do the pump and regulator and it still has the same fault? after all there are no fault codes? a friend of mine suggested fuel air mix? any thought
    New Member andy101's Avatar
    dudley
    Default fault
    hi
    it may be the idle control valve as that what happened to my old vectra sri 140 and it's a cheap fix
    as it was starving the fuel input
    kent
    thanks guys andy would the idle control valve show on the computer thingy? and would it cause these pproblems im experiencing im a complete novice with cars im the sort that buy a car and drive it my knowlede of cars is where i put the petrol and thats it?
    kent
    oh and its drinking petrol like its going out of fashion, my mpg is down to 15
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There is no idle control valve on the 2.2, the actual butterfly does its job. It wont be the Fuel pump/reg problem if you have the z22se as it doesn't have the HP pump only the pump in the tank. If however you have a z22yh then....... Do you drive a hatch or estate?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Hi Louise, welcome
    15 mpg? Would have thought you'd get more than that, unless you're thrashing it Fuel / air mix could be way out. Was the yellow light on when it was connected to the computer, or had it gone out? Was it a spanner light, or the emissions light?
    kent
    its defo the z22se as its the older engine i had that confirmed by vauxhall its a hatch not the estate with full irmscher body kit ps whats the butterfly?
    Vehicle : SRi
    Mileage : 137000
    Right so its not the fuel pump/reg then so its not going to be that expensive. The butterfly controls the amount of air the engine gets.
    It could be an air leak after the throttle body, or a problem with the TB itself.
  1. First real Mod
    By glasgowdarren in forum Styling
    Last Post: 29th April 2012, 18:36
  2. Real Sun
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 11th April 2010, 14:54
  3. are these real
    By neverlandandy in forum General Chat
    Last Post: 23rd December 2008, 11:27
