Thread: Oil filter 19 Cdti help
    Bristol
    Default Oil filter 19 Cdti help
    Hi, anybody got any photos on where the oil filter is on a 19cdti 150bhp Sri
    Regular Member RobW's Avatar
    Tain - Easter Ross
    No pics but its at the back of the engine, about half way down, or up, whichever way you look at it.
    I found best bet is to ask a garage if you can 'borrow' a ramp for half an hour and get it from underneath.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    http://www.vectra-c.com/forum/showthread.php?t=106826
    Here's a thread i posted on, it shows the location & rear view of the complete engine.
    Bristol
    Vehicle : CDTI 150
    You need a 32mm socket for the cap, access is poor with a ratchet you can only get about a quarter of a turn each time. Don't overtighten its torqued to 25nm; handtight and a bit.
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    here you go mate, sorry i am unable to circle the item for you, its the canister at the bottom left of the engine with the black cap, remove the little yellow sleeve on the bottom of the housing before unscrewing the cap, the oil will drain from this.
    hope this helps
    Attachment 38132
    Bristol
    Thanks guys, will have to have a look at this and see if i crack it my self.
    Bristol
    Thanks guys, will have a look at this and see if i can crack this job myself.
  1. Help!!! CDTi oil filter
    By 123rado in forum Engine & Drivetrain
    Last Post: 17th March 2012, 18:58
  2. cdti air filter help
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 19:51
  3. 1.9 CDTi oil filter
    By dalcock in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2010, 18:43
  4. What oil filter for 1.9 cdti 150 ?
    By Fash in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 20:04
  5. V6 CDTI Air Filter
    By r.bailey63 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 01:16
