Thread: Coolant leak
    Oct 2010
    Leeds
    Angry Coolant leak
    Car is doing my head in! my car has very small coolant leak and when idling holds the coolant with no great loss, as I soon as I touch the accelerator then my coolant just disappears.
    Any ideas much appreciated!
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    When you say disappears - you mean all of it? Do you drive it to and from work and top up daily or is it just being tested while stationary? Is there steam from the exhaust? Footwell damp.
    You are going to have to give us some more info to work on fella.
    Regular Member Exclusive BV's Avatar
    West Midlands
    Can you see where the stuff is going? damp patch on floor or engine bay
    Check under the oil filler cap for white gunk, hopefully there wont be any
    Bristol
    Vehicle : CDTI 150
    Any 'witness marks' on hoses, radiator, expansion bottle.
    Could just need a new expansion bottle cap.
    stockport
    Arrow
    Just stick some Radweld or any good type of radiator sealer in,that should sort it out. FELIXX
    Oct 2007
    Shropshire
    If it is not visabilty leaking and disappears faster with revs it sounds like head gasket. Do a cylinder leakage test to confirm.....
    Oh and if you care about your car don't use radseal. It normally does fix the leak but it might not and it can also block waterways. If it limits flow through one of the internal coolant ways in the block it can overheat and once its in its virtually impossible to get out. I had a mate who used it. The car was fine for a year and a bit but he hit some traffic on the motorway on a hot day. It over heated and the head warped. It needed new engine. When the old one was removed you could see the coolant passage in the block for number four cylinder was barely passable....
    Radseal is a bodge and does not fix it properly. perhaps its fine to sell it on...
    Devon
    Sorry to say my car had the same symptoms last year. Used about 1 litre of water per 20 miles, coolant light kept coming on, temperature gauge all over the place. However no sign of leakage and no mayo under the oil filler cap.
    It was the head gasket, so I part-exchanged it quick.
    Not what you want to hear I know, I hope it's something simple for you mate, good luck...
  1. coolant leak
    By DavyB in forum Insignia car chat
    Last Post: 17th May 2012, 09:04
  2. Coolant Leak
    By Sike in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 13:52
  3. Coolant leak
    By mzctc7 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 11:26
  4. Coolant Leak
    By trickydickySRI in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2009, 09:25
  5. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
