Results 1 to 10 of 11
Thread: steering arm
    Glasgow
    Default steering arm
    Guys evans halshaw have said my o/s steering arm is worn, can any one tell me what this part is? or where to get it cheap?
    my tracking keeps going out and today i had to yet again buy a new tyre!
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    That will be why you keep going through tyres then. Track rod end to you and me.
    http://cgi.ebay.co.uk/RH-TRACK-ROD-E...ht_3050wt_1001
    or
    http://cgi.ebay.co.uk/LH-TRACK-ROD-E...ht_3011wt_1001
    They are handed.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    it sounds more like a tie rod, which goes between the rack and the track rod end, its about £20 from the dealers, but you will need to get the tracking re done,
    Glasgow
    thank god, they wanted £180!!!
    so its not this?
    http://www.google.co.uk/imgres?imgur...t:429,r:12,s:0
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Naw thats the lower suspension arm.
    Glasgow
    so its deffo the track rod end then cause it does say i would need my tracking done again.
    Great! thanks lads, that must be what that grinding/clicking feeling is thru the steering and what i hear!
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    To check you'll need a mate to help. Turn the steering fully inwards, with the engine running. Now look for the rod that connects to the Hub and grab the bit nearest the wheel, past the threaded rod. Get your mate to rock the steering, not a lot just from 5 past to 5 to. If it is the track rod end thats knackered you will feel a knocking.
    Glasgow
    well i phoned the garage that said that bit wwas worn and they confirmed its the track rod end they are reffering to. £154 fitted!!! LMFAO sure pal.
    Glasgow
    but then i phoned back as they said the track rod end was like £27.. so i couldnt understand where the £154 comes from, so he priced the full suspension arm at £165.. ??
    he wants me to go in and they will go thru it with me.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by twaiter View Post
    Go Somewhere Else
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. Steering wheel sign...power steering cut out..what can it be
    By vec3.2 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:07
vectra c steering arms
