Results 1 to 2 of 2
Thread: 2005 vectra estate tailgate aghhh!!!
    cumbria
    Default 2005 vectra estate tailgate aghhh!!!
    hi can anyone help please? went to car on sunday opened boot fine, tried closeing it and it wouldnt!!! banged it cleaned contacts etc to no avail. locked it opened it with remote then with boot release on drivers door and hey presto it shut. thinkung it may have dirt in it or it may of got frozen i cleaned the car and used the old wd40 on all contacts squeezed handle and it worked. brilliant i thought until the wife used it the following day same problem opened but wouldnt shut
    after playing about with the handle and the remote the motor whirred and then it shut, back out with wd40 and double checked all visual connectors, shut it hey presto worked well stayed shut. however now it wont open at all no noise no nothing!!! any ideas? is it electrical motor? switch? handle? any help will be gladly accepted as cant afford local garage price to look at it let alone fix it,many tthanks in anticaption
    PRESTON
    I had a similar thing once, strange it was after the wife used the car, but the door wouldn't open either on the remote or from the switch and the door open light was lit on the dash, but the door was closed. In the end, i pushed really hard on the door, forcing it as far onto the latch as possible and hey presto, the light on the dash went out and it operated fine. For some reason, it hadn't latched properly, even though the door was closed. I put it down to dirt in the floor latch as they are exposed to everything where they are on the car.
  1. Vectra C estate tailgate not shutting
    By spook123_uk in forum Bodywork & Interior
    Last Post: 13th January 2010, 14:41
  2. Rear Tailgate not Opening on vectra estate
    By si_sri in forum Bodywork & Interior
    Last Post: 28th November 2009, 21:06
  3. Vectra Estate power tailgate problem
    By Snizzers in forum Bodywork & Interior
    Last Post: 3rd June 2009, 23:03
  4. Vectra C Estate Stuck Tailgate Problem solved
    By samuel in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2008, 20:44
