Thread: 2.0T Alternator replacement
    Apr 2008
    Nottinghamshire
    Question 2.0T Alternator replacement
    Hi all , has anyone had the pleasure of changing the alternator on a Z20NET Vectra , I have one ordered for saturday as the old one is really struggling and could use any handy tips going as my Haynes manual does not take this engine into account! Does not look to be in really difficult place on the engine to remove but You never know.
    Is there a How2 for this , if not any advice would be greatly appreciated
    Neil
    Regular Member Jezzy's Avatar
    S.E
    I think you improve access by removing the driver's side front wheel and then taking off the front half of the wheel arch liner.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    as Jezzy says thay does make it easier to get to. I took mine wheel arch lining out the other day,, you need to new plastic rivets to reattach the rear part of it if you decide to take it completely out, the front part is just held on with two or three torx screws.
    btw the Saab 9-3 haynes manual covers this engine, its worthing having one as its the same car underneath the body..i have one, i think Jezzy does as well..
    S.E
    Quote Originally Posted by Caveman_nige View Post
    I do have one, but can only make use of the pictures, until I get around to learning to read.
  1. Alternator pulley - replacement has finally arrived
    By Caveman_nige in forum Engine & Drivetrain
    Last Post: 21st July 2017, 18:32
  2. normal voltages after alternator replacement?
    By Tamps in forum Engine & Drivetrain
    Last Post: 17th August 2012, 20:48
  3. Replies: 0
    Last Post: 8th December 2011, 22:15
  4. anyone need a new alternator try this
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2011, 09:40
  5. signum -alternator belt replacement
    By mike a in forum Engine & Drivetrain
    Last Post: 22nd September 2010, 18:14
