Thread: advice please..
    Dec 2005
    south shields
    Default advice please..
    recently my vec has got a liitle bit of slack on the clutch pedal, to the point where i have to pull the pedal up to engage the cruise control, the clutch otherwize seems to be working ok. what should i do, im hoping this will be an easy fix?
    also there is a nasty crack sometimes when i pull up the handbrake-whats that all about?
    thanks!
    lee
    Clutch pedal is easy.. the return spring is weak..VX did an 'in service' un-official recall on it and have a revised spring avaliable to buy if you have no warranty.. it's not dear and it's easy to fit.
    Crack on the handbrake?? either sticking rear handbrake quadrants on the caliper or it's the pawl and ratchet in the lever itself.. where does the noise seem to come from???
    Jul 2006
    Mexico
    I had this crack noise from the hand brake too....in my case I think has to do with the lever mechanismm itself or it´s plastic covers cause the noise comes from there. I just pull the thing slowly and doesn´t crakkk
    Dec 2005
    south shields
    well thanks guys, im glad the spring is an easy fix,
    and yeah your right it doesnt crack when pulled slowly oly problem is the other half doesnt seem to understand slowly!
    Nov 2005
    scotland
    clutch spring part number is 93 183 937
    Regular Member Harry's Avatar
    Uxbridge, London
    yep...the noise comes from within the actual lever housing itself.
    i had this problem and got the dealers to sort it out, hasn't cracked since!! awful noise it is too! i think the technician said that there was some slippage going on.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
