Thread: SRI CDTI 150 Blue smoke on startup
    Midlands
    Default SRI CDTI 150 Blue smoke on startup
    Hi,
    New to the forum, seems like on cold get a cloud of blue smoke and occassional judder at low revs, I've just purchased OP-COM and checked the car for any faults, nothing recorded which is a good thing but concerned with the blue smoke. It's seems like a slight misfire when it's juddering, I ran the special tests in OP-COM which should report values for the 4 injectors, unfortunately all the 4 values displayed were 0.00 and did not change even though I rev'd the car. I expected some deviation from the special tests so concerned why it was just displaying 0.00.
    Any help greatly appreciated.
    Suky
    Bristol
    Vehicle : CDTI 150
    Blue smoke is normally a sign of oil being burnt.
    If its worse when its been standing normally valve stem oil seals
    Regular Member TonyTM's Avatar
    Timisoara - Romania
    Injectors are not running corectly and it missfires for a couple of seconds. Only then it burns some of the oil that makes its way into the combustion chamber.
    Midlands
    Hi,
    The car had 2 glow plugs failed which have been replaced, I still of this juddering on idle and at low rev's, I've not lost any power as the performance is still there, whilst it's juddering I do notice blue smoke from the exhaust and also discovered blue smoke upon heavy acceleration....I've had the injectors tested by my local garage by a leak off test, all four filled the pots up about the same....I'm still suspecting that this is likely a injector problem as the juddering feels like a misfire....if anybody can shed some light on this issue I'd be very grateful.....Thanks
    Suky
  1. Little puff of Blue smoke on startup...
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 13th August 2012, 11:06
  2. SRI CDTI Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 8th February 2011, 12:01
  3. blue smoke on 1.9 cdti 150
    By big nath in forum Engine & Drivetrain
    Last Post: 26th November 2010, 09:44
  4. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
  5. White/blue smoke at startup
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 27th March 2008, 08:57
why does my vectra have blue smoke on startup
vectra c blue smoke and slight misfire
vectra cdti blue smoke site:www.vectra-c.com
