Thread: Reverse light switch
    Dec 2010
    wigan
    Default Reverse light switch
    My reversing lights stopped working and i discovered the plug has come off the switch. Ive can hold the plug in my hand just cant locate the switch to plug it in and ive looked everywere i have even to battery and tray out to help see it but nothing. Any ideas or pictures of were it could be my car is a vectra c on 52 reg. Thanks
    Jul 2009
    The Rift, Cardiff
    You should see it down on the gear box when looking between the engine and bett box. It sort of resembles a spark plug with a plastic connector on top, bolted to the top of the gb pointing slightly towards the radiator.
    Dec 2010
    wigan
    thanks for reply i have looked everywhere on gb and cant find it no were its mind boggling.
    Engine : 1.9 CDTi
    I think its accessed from the passenger side inner wheel arch area.
    Take the wheel off and you should be able to see it.
    What engine do you have and is it 5 or 6 speed?
    Dec 2010
    wigan
    its a 1.8 and 5 speed thanks
    Engine : 1.9 CDTi
    It that case maybe in the front of the casing near the selector linkage.
    Dec 2010
    wigan
    Ive still not found it. Will it be hiden? starting to think has it worked lose and fell off. It couldnt be far away as i can hold the plug it supose go to and that dont stretch far
    Engine : 1.9 CDTi
    Ask in your local area section or take it to a garage and ask them where it is.
    Jul 2009
    The Rift, Cardiff
    Here's my switch
    Dec 2010
    wigan
    Ive been told mine is on top of box next to linkage and it gets removed to put gearbox oil in and according to the garage its just got a sump plug in instead of the switch so i have to go and buy a switch and replace the sump plug with it. Thanks for the picture
  1. Signum reverse switch cabling?
    By mudcow007 in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 14:14
  2. Reverse 24-LED Light Bulb
    By stuwieb in forum Styling
    Last Post: 14th April 2011, 12:04
  3. is this were reverse light switch is supposed to be?
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2011, 13:49
  4. where is the reverse light switch on vectra 52 reg
    Last Post: 8th December 2010, 20:19
  5. Reverse light switch Signum 2.0T
    By olajon in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 13:23
fae reverse light switch 2004 vectra location
vectra c reverse light switch
reverse light switch location insignia
Vauxhall vectra reverse switch
VAUXHALL INSIGNIA GEAR BOX REVERSING SWITCH
REVERSING SWITCH VAUXHALL INSIGNIA
where to find reverse light switch on vectra c facelift
vectra c facelift reverse light
reverse light sensor connector vectra c 1.9 cdti
vectra c reverse light switch automatic
what socket for the reverse switch on vauxhall vectra 1.9cdti
1.9 turbo diesel reversing switch Vectra
vauxhall vectra cdti 2008 reverse lights swith
03 vectra c reverse lights switch
opel vectra b reverse light switch location
