Results 1 to 10 of 22
Thread: Vectra C - Z18XE Engine Number Sequence....
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    confused Vectra C - Z18XE Engine Number Sequence....
    Can anyone kindly point me in the right direction re. Start & Finish of engine numbers for this engine in the C... (& Signum??)
    Reason I ask is I'm about to change the cam belt with a Gates kit & have visited Gates Europe web site to check what I need to be sure I get the right one for the car from a local motor factors....
    Our 55 reg facelift Vectra C has the Z18XE pre VVT engine fitted & is
    just over 5 years old & 48K+ miles which we got with 3933 miles on the clock & 8 months old.
    The Service book advises a cambelt change @ 6 years or 60K miles...
    Gates Europe site advises their -
    Kit number KO 25499XS for engine numbers upto 20EK2285 &
    Kit number KO 35499XS for engine numbers from 20EK2286...
    with the Micro V belt given as 5PK 1240XS for both ranges.
    Our 55 reg facelift Vectra C has the Z18XE pre VVT engine fitted & the
    Engine Number is 20GH0020 & alphabetically would appear to be after :
    20EK2286 & thus requiring kit no KO 35499XS & micro V belt 5PK 1240XS...........
    However it appears to be fitted with Micro V belt 5PK 1255....
    If any of you techies out there can help I'd be grateful
    Thanks....
    May 2008
    Tyneside
    The aux drivebelt no indicates the length i.e. 5PK 1240XS is 5 point 1240mm long. If you have a 5PK 1255 fitted then a 5PK 1240 is too short and will not fit. I have a Z18XE engine on an 03 plate and buy timing kits from Autovaux, genuine Vauxhall parts (manufactured by Gates). All they require is reg no to identify kit.
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by tridley View Post
    Thanks mate....appreciate your comments but was only of thinking of changing that one as well as VX don't advise any time or mileage.....but I'm more interested in the cam belt kit reference in respect of my engine number .......Interestingly what kit number & micro V belt number was right for your 1.8...
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Sorry not much help here. I bought a genuine VX timing belt kit for my z18xe, I bought mine off ebay for basically half the price it is at the dealers. My engine number is 20CR, so id assume that you would work in an alphabetical order too, yours being the latter number.
    http://cgi.ebay.co.uk/Vauxhall-Cambe...m#ht_500wt_949
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    confused
    Cheers Mate...comment appreciated...thought Gates Europe Web would be the place to look to make sure I got the right kit & micro V belt numbers...
    Bl**dy difficult sometimes to get information about parts that fit 'our cars'...eh'
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Just had a quick look on Eurocarparts, and they only list one Belt for the z18xe.
    Can you email gates with your engine number and ask them to double check which one you need?
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    My car is register May 2004 Z18XE - 20CY6065 if that is any help to you sorting out code sequence
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Hi again Das.....Did just that a couple o' days or so back...no response to date from 'em.
    I can always hope. eh'
    Interestingly Vauxhall World Parts have just emailed me with a part number for the Mico V belt...5PK 1245....
    That's 3 x different numbers so far.....
    Oct 2009
    Luton
    The Z18XE engine was built at a single production plant, Szentgotthard. This plant has a code of '20' and appears at the start of the engine serial number.
    The first engine off the production line was '20P88010' and was built in June 2000 . The engine number progression sequence is...
    20 000001
    20 999999
    20 A00001
    20 A99999
    20 Z99999
    20 AA0001
    20 AA9999
    20 AB0001 etc
    If there is any number other than '20' at the start of the serial number it is a mistake.
    From a OE service perspective there is only 1 belt for this engine PN 24451895 or there is a kit 93185845 with improved tensioner and roller design. These fit all Vecra-C / Signum.
    Hope this helps!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by I cdti View Post
    20 000001
    20 999999
    20 A00001
    20 A99999
    20 Z99999
    20 AA0001
    20 AA9999
    20 AB0001 etc
    Hope this helps!
    Which Takes You Back To The Link DasArab Posted Up
  1. Z18XE Engine - GM Oil Filter Part Number
    By wafoo in forum Engine & Drivetrain
    Last Post: 15th June 2012, 11:31
  2. z18xe engine
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 5th March 2010, 23:39
  3. Correct oil for Z18XE engine
    By Bobtroll in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:52
  4. vectra engine number
    By Dean82 in forum Engine & Drivetrain
    Last Post: 4th July 2008, 09:48
  5. VIN & Engine Number Lacation on Vectra
    By nickabbott2008 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 23:43
z18xe aux belt length
z18xe 1989 engine number
vauxhall z18ex engine number
z18xe engine serial number
z18xe number engine
