Thread: Is this a Known Problem - Loss of Power?
    UK
    Default Is this a Known Problem - Loss of Power?
    I have a 2005 Vauxhall Vectra 1.9 CDTi (150) SRi auto. I have noted that in the summer months (heat a factor?) on a motorway run at a steady 75mph (never around town no matter length of journey) approx 75% of journeys at some point I get the Engine Electronics, Immobiliser symbol lights up on the dash (a car with a vertical spanner in the middle of it). I have had the car serviced and the CPU checked/reset. Two things happens when this light comes on. I get a loss of power, I can coast along at 70mph (if I were doing 70mph) but there is no acceleration and if I get to a hill the car will slow down; the accelerator pedal has no effect. If the cruise control was on at the time the dash board light comes on 99% of the time the cruise control cuts out and you cannot switch it on again. The remedy is to stop the car, switch off the ignition and restart - all is well again. It seems to me a CPU issue as restarting re-sets the electronics but I have had this checked. Any advise appreciated.
    Full Member gibbon7000's Avatar
    lincs
    By the sounds of it the car is going into limp mode to protect it self from damage, If the spanner light is coming on then there is defo a problem somewhere and the car will store a fault code to say what that problem is. You need to get the codes read.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Full Member Big Sig's Avatar
    it's also indicated what the symbol means in the manual.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If it's anything like the DTi the boost sensor may be needing a clean. The DTi goes into limp home mode and doesn't store a code when there is overboost detected. Worth a shot
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Might it be the DPF regen'ing?
    UK
    Thank you for the replies. The codes did not show anything - I have had an 'expert' who has the appropriate tools look at this and there is nothing in the codes that point to anything. I am interested in the boost sensor and 'DPF regen'ing'. Is the boost sensor easy to access/clean and where is it located? Also, apologies for my ignorance, what do you mean by DPF regen'ing?
    Quote Originally Posted by mally View Post
    No, that won't bring on a fault.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by quarkrad View Post
    I had this on my 2005 cdti auto,and thought it was everything and anything at the time,i cured it after taking out the insides of the dpf.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. problem with signum 2.0 dti loss of power
    By unhappy of wales in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 21:38
  3. Idle problem, loss of power, engine management light on.
    By Coyney in forum Engine & Drivetrain
    Last Post: 10th July 2011, 10:57
  4. PLEASE HELP! CDTI 150 Power loss problem
    By jujitsuboy69 in forum Engine & Drivetrain
    Last Post: 12th April 2010, 23:12
  5. 2.2DTI Power loss and starting problem
    By grslewis in forum Engine & Drivetrain
    Last Post: 21st April 2008, 16:38
