Thread: K & N induction kit
    Luton
    Question K & N induction kit
    Hi there
    I'm new here and i wanted to find out any additional info about the K & N induction kit i just fitted to my vec C elegance. i have fitted the kit as per instructions but wanted to know what to do next? Are there any additional steps i need to take to improve performance in terms of the air intake?
    Nice one for any help
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yes mate, you need to take it off. Your car will have less power with it fitted. Unless you have a sealed kit all you will be doing is sucking in hot air.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    What Rushy said, you need either a fully enclosed cone filter with a good cold air feed or a K&N panel in the standard box. Vauxhall engines run so hot, the heat soak actually makes the performance worse with an open filter.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Ian-Highlander View Post
    VAUXHALL engines run so hot,,, have I missed somthing?
    all I can say is when I bought my last vec-b it had an open cone k&n filter, the car ran great, it was very quick, it was a 1.6, ( a lot quicker off the mark than my 1.8 vec-c), summer or winter never had a problem and gave good MPG, er,,,,, until I cleaned it.
    It's a bit of a debate, makes you wonder why most of the big power tuned cars use open foam filters?????
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Because they tend to have huge turbos and intercoolers mate. The earlyer VX's ran fine with them but the newer ones dont.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    I guess the only way to prove this, right or wrong, would be with actual have rolling road figures for both. I used to run a 57i on my old cavi 130, I actually fabricated an aluminium plate to help stop heat soak. Never found any benefit with or without it tbh.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    They have on the 2.2 forum mate. The panel filter proved to work better than the open filter. The old C20XE's and LET's were fine with the open filter but the modern Ecotec's just don't like them.
    There's an article I read from the US where they took a Z20NET and the SC'd version and fitted a thermal gasket in between the head and intake manifold. With just the addition of the gasket there was an increase of power, only small but still there. If you think about it, the heat from the head with transfer into the manifold and in turn alter the intake temps.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Id be keen to try a cone filter on mine and do the aluminium plate to help with the heat soak, cant beat the roar from an induction kit.
  1. K&N Apollo CIS Universal Induction Kit vs. K&N 57i Induction Kit
    By LAZZEE RARSE in forum Petrol Engine related
    Last Post: 26th July 2010, 22:13
  2. Induction kit
    By andyprice86 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 14:00
  3. new induction kit on :D
    By damadom in forum Petrol Engine related
    Last Post: 15th May 2009, 10:54
  4. Induction Kit
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 23:17
  5. Induction kit or not?????
    By stubopvectra in forum Diesel Engine related
    Last Post: 22nd April 2008, 15:36
