Thread: Chrome boot trim removal
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    Default Chrome boot trim removal
    Ive seen lots of threads on here regarding removing the chrome boot trim to colour code it. I have just done my own and thought i would give some tips on removing it.
    Firstly you need to remove the boots inner trim panel, then remove 4 x nuts which hold the strip on, 2 nuts hold the boot button fitting in place, the other 2 are on the inner boot lid just near the edge, you cant miss them.
    Once the nuts are removed there are four square clips which will still be holding the trim on, dont try and pull the trim towards you to remove it as you will break the clips and bend the trim if you pull too hard. If you pull the trim towrds you a couple of mm's at one end you will be able to see the first clip. While pulling the trim a few mm's away from the boot lid at one end, slide your fingers along the bottom edge of the trim and push the trim up, as if your trying to push the trim towards the boot lip spoiler and the first clip will release. Then go to the opposite end and repeat this. Once both outer clips are free you can pull the trim a little further away from the boot towards you, do the same process with the last 2 remaing clips, dont worry you wont scratch the boot lid. When the strip is removed the clips will be left on the boot lid. If you are careful you can then open up the 4 prongs on the clips and remove them to refit if required. I have chosen to leave mine off as i feel the 4 nuts are more than enough to secure the trim and would be even easier to remove if and when required.
    Hope this can help a few people out and i will take some pictues tomorrow to give people an even better idea.
    Jan 2010
    stockton on tees
    Here are the pictures -
    with the crome trim removed, this is what is behind the trim on your boot lid -
    Attachment 38079
    The pegs on the boot lid are what the 4 clips attach to -
    Attachment 38080
    At each end are the threaded clips -
    Attachment 38081
    Attachment 38082
    The clips are attached to back of the trim by slotting into a lip running along the top and bottom of the rear of the trim -
    Attachment 38083
    Along the bottom lip are slots which locate the clips so you dont have trouble lining them back up to refit. I decided to leave mine off as the 4 threaded clips are more than enough to hold the trim on, its a personal choice though -
    Attachment 38085
    Attachment 38086
    Attachment 38087
    The following picture will give you an idea why you lift the trim rather than pull it to remove it, it unhooks over the clips top lip to remove. The second picture shows the clip pushed fully home.
    Attachment 38088
    Attachment 38083
    Last but not least pictures of the plastic trim around the rear of the boot button slot, also showing the other 2 x threaded trim attachments, this can be removed so you dont get overspary all over it if you are colour coding. Just pop out the 6 x clips to remove from the trim -
    Attachment 38090
    Attachment 38091
    As for the colour coding you can achieve a good finish with rattle cans, dull the chrome with wet and dry, use acid etch primer followed by top coat and laquer. I used halfords cans and the colour match is spot on, a tip, keep the paint warm with a heat gun etc for the perfect finish. Not great pics but heres an idea what can be achieved, these where taken before any polishing and is sprayed Sapphire Black -
    Attachment 38092
    Attachment 38093
    Attachment 38094
    Hope this thread will help people out, i guess im trying to give a little back for all the folks who have put things on here to help others.
    Thanks for checking it out
    in a house
    Great how 2 fella, welldone.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Wish I had seen this last week lee
    Had the chrome strip off to fix boot lock as it had give up the ghost. Ended up snapping all 4 of the black plastic clips trying to pop them off the studs in the boot. Only after flipping the chrome strip over I realised that lifting the strip upwards is the way to pop them off
    So am going to pop into my local VX dealer and get some replacements
    So for those that need to replace any of the clips I am led to believe that the part number is:-
    9177069 CLIP-LOWER MOULDING TO TAILGATE (Hatchback) (Thats for the inner 4 that pop onto the studs in the boot)
    Not sure if they are any different for Saloon or Estate
    Anyway great HOW-TO lee I'm sure it will come in very handy to others in similar situations
    Damo
    Oct 2011
    Belfast
    Excellent how to, I,m taking mine off so I can carbon fibre it cheers G
    Regular Member bigbranno9's Avatar
    Jan 2012
    middlesbough
    Hi Lee do you still have your spoiler for sale ?
    wales
    I haven't bought a Vectra (yet!) but is it possible to remove the words off the boot strip? or are they part of the strip? Cheers.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    They come straight off like any debadging method
    wales
    Thanks mate
    Jan 2012
    Ireland
    Trim : SRI 120 Hatchback
    Engine : Z19DT
    Great how to. I was trying to remove the tailgate chrome strip to wrap it yesterday & stopped short of bending the strip or breaking clips. I knew I'd find the right info here, thanks a million
  1. chrome boot trim
    By DAVIDD88 in forum Parts for sale
    Last Post: 7th March 2011, 13:32
  2. Chrome boot trim
    By Liam1984 in forum Detailing and Car Care Discussion
    Last Post: 13th April 2010, 23:00
  3. interior boot trim removal??
    By hagga in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2009, 20:22
  4. boot chrome trim
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 12:37
  5. remove chrome boot trim?
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 17th August 2008, 14:25
how to remove tailgate bootlid from vectra c
vectra c boot trim removal
Colour coding chrome boot trim
remove vectra lip spoiler
how to remove interior boot trim on a vauxhall signum
how do i remove a vectra c boot trim
chrome trim vectra c
how to change vectra c chrome interior
how to remove vectra c rear chrome boot stripe
How to remove vectra boot spoiler
remove boot trim vectra
fit vectra tailgate chrome
remove chrome vectra
remove vectra boot strip
