Results 1 to 10 of 13
Thread: Brake light puzzle
    Dec 2010
    Bath
    Default Brake light puzzle
    Evening folks, looking for some bright ideas. A warning light came up this evening on the information screen saying 'Brake Light'. It happened straight after I'd slammed the tailgate having loaded the shopping. Checked the fuse and it's ok, removed the bulb holder and they also all appear ok. Got the girlfriend to step on the brakes and sure enough both light up. BUT, the left brake light appears to be two bulbs deep whilst the right appears to be only one deep - if you get what I mean. So, I switched on the tail-lights but bizarrely the reverse is true for those - RH side appears to be 2 bulbs deep, left only one.
    Confused Any bright ideas what's going on?
    My car's an 09 plate Vectra 1.8 petrol.
    Cheers, Mark.
    13 Post(s)
    When a brake light fails on a Vectra, the lower tail light takes over the role of tail/brake light.
    ie, when everything is ok - from top to bottom
    Indicator
    Tail light / brake light
    Tail light
    Fog tail light (drivers side only)
    Reversing light
    But when the brake light fails:-
    Indicator
    no light
    Reversing light
    Dec 2010
    Bath
    Thanks Dave for such a fast response. I've since found lots of other threads talking about the same issue, apologies for going over old ground. I'll have a play tomorrow during daylight - I only checked the right hand cluster tonight, it sounds like it is most likely the left hand instead. I'll switch some bulbs around and see what response I get.
    Many thanks again - every issue I've had with the car so far has been resolved through this forum!
    Mark.
    Trick as well, is to replace the equivalent bulb on the other side
    So if you replace the upper 21W, replace the same on the other side
    The other one to watch out for is when a side light goes it will illuminate the indicator.
    Not on mine, I just get the warning message "Parking Light"
    13 Post(s)
    Same here. No indicator was lit when my front sidelight failed.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It does on the earlier cars, mine does it 53 plate
    It should do, it did on both my signum and Vec, I have also seen locally a few with this lit and there are threads about it on here where people have detailed this.
    13 Post(s)
    Mine is July 06 registered.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Car / Spanner light puzzle
    By moneypit in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 01:04
  3. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  4. Mat Puzzle
    By it0011 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 14:19
  5. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
