Thread: Buying info
    ireland
    Question Buying info
    Hi there. New here looking for a bit of info on what to watch out for when buyin a vectra , looking at 04~07 1.9 CDTi sri 150BPH. I'v heard good and bad reports . What you think guys. I know most of the guys on hear are more into big petrol ones i'd be the same only for the ****in road tax over hear in Ireland cheers lads
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You'll be surprised, there's probably more CDTi's on here than anything else lol
    The main things to watch out for on the 150's are the DMF (Dual Mass Flywheel) and injector rails as far as I know, but I'm no expert on them, I don't have one and prefer the gas guzzling petrol engines
    Good luck finding what you want though, I'm sure someone more knowledgable than me on them will be along shortly to help you. Welcome to the site
    Don't forget the egr and inlet manifold's. Plus they are not cheap to fix.
    Sep 2009
    middlesbrough
    you hear alot of problems because there are so many on the road, once the common problems are sorted they should be fine
    dual mass flywheel - vibration through pedal and rattle from nsf of engine - parts alone are about £400-£500
    inlet manifold - symtoms inc sluggish under 2k revs, can check this by looking to see if the rod that moves the swirl valves is still attached - just cost me £500 but this inc cambelt and waterpump change
    egr valve - similar symtoms to the inlet manifold failing, can be cleaned eaily yourself which cures most problems, about £100 for a replacement if neccessary
    alternators are also quite common to fail, thats all i can think of
    ireland
    Cheers lads for the info. Whats the erg valve .. I'm just looking at cars at the moment and like the look of the vectras.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by conmacirl22 View Post
    EGR (Exhaust Gas Recirculation) Valve:
    A solenoid operated valve that diverts some of the exhaust gas back into the engine intake air when the engine is cold. The idea is that it helps burn unburnt fuel and causes the engine to warm up to temperature faster thus getting the catalytic convertor up to temperature faster, thus reducing emissions.
    Simple enough to remove and clean.
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Hi. New & looking for info re: buying
    By Bev in forum Introduce yourself.
    Last Post: 16th May 2011, 20:22
  3. Help buying a SRI 120 or 150 with or without SAT NAv
    By uncle in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 20:38
  4. Buying info
    By RRB in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2006, 19:02
  5. Help - buying info req.
    By Baldy in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2006, 00:16
