Results 1 to 10 of 17
Thread: wiper problem on slow setting?
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default wiper problem on slow setting?
    any one able to help with this one
    on the my 52 plate vec the wipers on the slowest setting seam to have a mind of there own as to if they want to work or not
    now the rest of them work on fast and really fast setting no problem
    the problem comes when i have them in the intemitant(sp) setting. if i do they will wipe the scren 2 or three times sometimes more and then stop working and wont work untill i change the adjustment on the stalk and they will go again.
    any ideas what this could be?
    Sep 2010
    Milton Keynes
    do you have rain sensing wipers ?
    Kent
    Trim : SRI
    Quote Originally Posted by BMAstra View Post
    good question how would i know??
    What model do you have?
    Also top of the screen behind the mirror you will have a blue/purple looking sensor. i think you would also have an auto dip rear view mirror.
    Nottinghamshire
    You will have a sensor next to the rear-view mirror pressed against the inside of the windscreen facing outwards - look for it from the outside of the windscreen.
    If you think you have this, push the wiper stalk up once (intermittent mode, wipers wipe once to confirm) then chuck some water over the sensor and this should set the wipers going.
    Also, if you move the sensitivity setting (the lever on top of the wiper stalk) from left to right (from less to more sensitive), the wipers will wipe once each time you move the lever a notch to confirm.
    Kent
    Trim : SRI
    then yes i do as i have a auto dim mirror and what you say is a sensor on the windscreen.
    are these known for being faulty?
    Not really, but as you didn't know you had them I am guessing you don't know how to adjust the sensitivity as you thought it was the intermittent timer adjustment. Do you have a manual?
    Kent
    Trim : SRI
    lol some where will have to dig it out
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    There is a toggle switch ontop of your wiper stalk... it adjust sensitivity, left is less, right is more
    I find on the low setting though it can be a little lazy unless its on the most sensitive setting... which is always a little over the top lol!
    It also adjust the speed of your rear wiper too
    Kent
    Trim : SRI
    Quote Originally Posted by luke4487 View Post
    cheers i noticed when adjusting this that the speed did change but as said it can stop after a few wipes even if its still raining out side at the min i have it on the most sensative setting
  1. Front wiper - full speed setting
    By preecy in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2012, 13:19
  3. Wiper problem
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2012, 11:43
  4. Signum heater problem (only setting 4)
    By alh8692 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2010, 20:02
  5. 2.2dti slow to start problem?
    By Craig1985 in forum Engine & Drivetrain
    Last Post: 24th September 2009, 15:42
