Thread: Headlight Bulb Replacement
    UK
    Default Headlight Bulb Replacement
    Hi guys,
    I have a Vectra C 04 (Non facelift) and was wondering how to replace the bulbs, I can access the bulbs ok and have removed the rubber black cover, but im unsure how i actually unscrew the bulbs that are already there and refit the new ones I have (H7 bulbs), I have already searched the forums and found info explaining how to gain access to the bulbs but not much info on how they are removed. Any help would be much appreciated.
    Many Thanks
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Its a sort of twistlock spring clip holding the headlight bulbs in. Disconnect the wire plug, and then holding the top and bottom of the silver clip twist it anticlockwise.
    stockport
    Arrow
    They just twist out,anti clockwise,then pull the old bulb from the holder and fit in the new one,without touching the glass with your fingers.Refit etc.No problem. FELIXX.
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    if i can remeber right you remove the plug on the bulb and then push and turn the fitting around the base of the bulb, it will only turn one way, remove the fitting then take out the bulb. They come off very easy but can be a little awkward when refitting. Just remeber which way the holder turns when removing and do the reverse when refitting, its amazing how you forget which way you removed it when it comes to putting it back on lol
    I think the main beam bulbs are screwed in with torx screws if you ever needed to remove them, very easy to do.
    Oh and you need to remove the washer bottle neck to change the passenger side bulbs, also very straight forward.
    Hope this helps..
    UK
    hey thanks a lot guys i managed to change both bulbs quite easily following your instructions!! shame the bulbs i got sucked and produced less light than the ones they were replacing!!! what a dissapointment *sigh*
  1. headlight bulb replacement FACELIFT
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2012, 18:42
  2. Headlight bulb replacement?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 17:33
  3. Headlight Bulb Replacement
    By Hallzer in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2008, 16:12
  4. Headlight bulb replacement
    By mzctc7 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2008, 09:50
  5. Headlight bulb replacement
    By Davexctra in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 17:06
