Thread: DMF or Thrust bearing
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 106000
    confused DMF or Thrust bearing
    Just driven with view to buying a 1.9CDTi 07reg with 50k on the clock, it drives very well, smooth and responsive, but I noticed when I stopped there was a rattle comming from the front nearside.
    This rattle dissapeared when the clutch pedel was depressed and returns when the pedel is released, there is no vibration going through the clutch pedel nor is there anything wrong with the feel of the way the clutch works, it just has this knocking noise comming from the engine bay.
    Oct 2010
    north wales
    Dmf, just had mine done...... like a rattle rattle when the clutch pedal is press about 2inch's in then go's away when pressed all the way in then rattles again on the way back up in the same place???
    Clutch an dmf shuld be changed at same time, makes sence with the size of the job. Gear box out job.
    Mine was done under warrenty about £400 for clutch and DMF, could pay up to anything for £600 for labour?
    Hope this helps.....
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    all parts will cost you 600+ then fitting vx will say 1200 min
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 106000
    Quote Originally Posted by alexstudly View Post
    This one seems to rattle untill you put pressure on the clutch pedel, it goes away and comes back when you release it
    It does not make any noise when there is pressure on the clutch pedel, which bites about 1/2 way up/down.
    Sep 2010
    in a box
    its DMF mate as mine was same press clutch down gone, clutch up comes back
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 106000
    how long will it last and what will happen, will it fall apart or just no clutch at all
    Sep 2009
    middlesbrough
    to be honest mate it could last a week it could last ages, the thing is there are that many other vecs out there, is it worth it, if you can get the price down to accomodate getting the work done or you can afford to get it done at least you then know it will have been done but dont just keep the rose tinted glasses on like i normally do, i got a bargain with my vec because i knew it needed work so i got money off it,
    Engine : 1.9 CDTi
    Is it a trade or private sale?
    Your looking at about £1k to have it repaired by a garage so get thet knocked off the price or get them to fix it first.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 106000
    its trade, when I mentioned it to the garage owner he said it works ok even though its knocking, he told me if I bought it with a years warranty they would repair it when it went wrong, I said what if it does not go wrong in the first year as I only do 6k per year.
    His answer was to purchase another years warranty.
  1. Worn Thrust Bearing?
    By LeeU in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 09:24
  2. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  3. Thrust Bearing 1.9cdti 120
    By stevie16v in forum Engine & Drivetrain
    Last Post: 11th May 2011, 18:08
  4. Thrust bearing noise
    By robengland9 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 13:48
  5. 3.2 GSI Thrust/Clutch bearing Question.
    By gsi32 in forum Engine & Drivetrain
    Last Post: 4th February 2009, 13:45
