Thread: Need replacement springs for SRi 2.2DTi...
    Regular Member Innes's Avatar
    Plymouth
    Default Need replacement springs for SRi 2.2DTi...
    I had the car serviced the other day and they said the rear springs look corroded and recommended to change them. I've read enough on the forum to know that the Vauxhall standard springs are prone to snapping so I'm looking for the same size springs that are more reliable.
    I'm not that bothered about lowering the car as I think the SRi is low enough on its standard springs and I don't want the ride to be any harder than it already is. Plus it would also mean replacing all 4 springs instead of just the rears.
    Any recommendations and/or links to what I need?
    Regular Member Dazzy2006's Avatar
    Notts
    I replaced both rears on mine from local auto factors - iirc it cost around £70 for both. The back springs are a doddle to change and should take about an hour.
    The 1st part of the how to below is pretty handy to
    http://www.vectra-c.com/forum/showthread.php?t=46991
    Plymouth
    I've been looking in Euro Car Parts and they do two versions:
    http://www.eurocarparts.com/ecp/c/Va...c82cefe93&COIS
    and
    http://www.eurocarparts.com/ecp/c/Va...5be2e7588&COIS
    I have an SRi so I think I need to go for the 2nd link as it says ;lowered chasis' in the description.
    Is that correct? Has anyone bought SRi springs from Euro Car Part?
    West
    yes as it's an sri you need the lowered/sports chassis type
  1. Replies: 30
    Last Post: 19th August 2011, 01:08
  2. 2.2dti clutch replacement
    By John LE in forum Engine & Drivetrain
    Last Post: 5th July 2011, 21:01
  3. 2.2dti sri springs?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 15:51
  4. 2.2dti intercooler pipe replacement help?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2010, 21:27
  5. 2.2DTi brake disc size upgrade and shock and spring replacement
    By Mogsy007 in forum Handling & Braking
    Last Post: 14th February 2010, 13:25
