View Poll Results: Have you removed your EGR Valve?
Voters
13. You may not vote on this poll
  • Yes
    6 46.15%
  • No
    7 53.85%
Thread: Have you removed your EGR Valve?
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Have you removed your EGR Valve?
    I hear loads of people keep cleaning their EGR Valve, so just wondering how many people have removed it instead.
    Aug 2010
    Leeds
    Not cleaning it i will just replace it when it's clogged up.
    stockport
    Thumbs up
    NO.Have had it off and cleaned on a couple of occasions,so,this time,I put a new one back on,I am thinking of semi blanking it now that I have done the CCV
    mod thanks to winnie. FELIXX.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Ordered up a 2mm blanking plate from Ebay. This is when I get remap to delete it as that's the only way with the CDTI's.
    I ain't spending £100+ on a new valve. Then there is the cleaning of the current one. Sorry had all the parts off - waste of time. Car is still down on power.
    The soot is the manifold killer not the oil itself - hence it would be better for the car if it was eliminated.
    Gazza4
    stockport
    Thumbs down
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    That's exactly why I think you are spot on.What sort of remap are you going to have?,as there is a remap specialist about 2 miles away.If it's not too expensive I'm def going to go for it!!. FELIXX. (By the way,am going to pm you about an idea re the EGR and see what you think).
    Edinburgh
    Had mine off the other day and cleaned the valve part (didn't punch out the solenoid) and its the solenoid that seems to be the issue (doesn't move when car started appears stuck in the closed position). Just going to replace valve when I get paid. Might get new gasket that restricts gas flow.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by felixx View Post
    Pm'd you back. Very interesting theory and could work very well. You will be getting round the EGR blanking problem with at. Bear in mind that the valve itself is still not eliminated. Like I say sounds good.
    Pm winnie he went to these guys:
    http://www.masperformance.co.uk/diesel-tuning/
    Quote Originally Posted by Big Knox View Post
    Make sure they update the ECU with the correct software too. Point it out to them before it goes in.
    Gazza4
    Regular Member Mopar Man's Avatar
    herts
    Biscuit tin lid cut with two 4mm holes, job done with now EGR light on
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. dpf removed
    By figo1805 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 16:59
  3. EGR Valve: removed but looks like new!
    By somerled76 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 16:44
  4. Should i get it removed
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 23:04
  5. Can the EGR valve be removed from a 2.0l DTi (52 plate)???
    By merikiito in forum Engine & Drivetrain
    Last Post: 4th September 2008, 09:25
