Thread: Diesel around the swirl valve seats.
    stockport
    Exclamation Diesel around the swirl valve seats.
    Had the veccy in yesterday for a service.I had also noticed that the valve seats/flaps on the inlet manifold were getting a bit on the gunky side,so I asked them to check if they were leaking.Came back with,"It's diesel sir,and will need further investigation to find out where it's coming from".Now there IS diesel there though,and it's more noticable after a run,AND,you do get a smell of it sometimes.Has anyone got any ideas where it may be coming from as I can't find any leaks at all!!!!. FELIXX.
    stockport
    Regular Member LADmachining's Avatar
    Hampshire
    If it is fresh Diesel, then it can only be coming from the fuel rail or it's associated pipework, which is in the area above the swirl flaps.
    If it's oil and other gunk, then its probably pushing past worn swirl flap bearings in the intake manifold.
    stockport
    Thumbs down
    Quote Originally Posted by LADmachining View Post
    Thanks for that.I had a suspicion that it may be something like that.I had it in VX today,(again!!),and they said that the inlet manifold was ok and that they couldn't find anything wrong,so to leave it for a while and see if anything develops.I think I will run my own "cottage industry" tests on it to see what's what.Watch this space!!...............FELIXX.
  1. Swirl Valve on a 150 Diesel......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 21:11
  2. Swirl valve bar off....
    By johnnyboy1985 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:04
  3. Egr valve, swirl valve problems etc..
  4. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  5. Swirl Valve
    By parsco in forum Engine & Drivetrain
    Last Post: 29th April 2009, 20:47
