Does anyone know the part no. for the lower lambda on the 2.0 T, please
No one got epc they can look it up on please
I'll check tomorrow when I'm back at work
There's a choice of 3 depending when your car was built, look at the last 8 digits of your VIN;
PN 55353269 for Ellesmere build up to chassis -48034284, for R'heim build -41039263
PN 93180670 for Ellesmere 48034285-, for R'heim 41039264-51065673
PN 93184704 for R'heim 51065674-
Hope that helps!
does anybody know if these are interchangable, i need the last one in the list and can't find one for sale other than going to the stealers.. I can find the first one on the list at a good price but if it won't work onthe later cars then its no good to me.. anybody been there?
I can get NGK one @ £87.00 inc vat.. PM me if needed
is that the two wire position 2 sensor with 1465mm cable?
Yep 1465mm long.. but shown as a 4 wire?
NGK list the Signum and Vectra as having the same one 03 onwards
hmmm, thanks bud, I am not keen on risking buying the wrong part or one that works but may cause me some issues. I know they are all pretty much the same thing. The front (position 1) sensor is the 4 wire on my car, the second (position 2) is the two wire sensor with the 1465mm of cable.. As far as i am aware they are also made by Bosch who invented the damn things,, Position 1 I can buy for £82 plus delivery..
Which of the two sensors is being measured to do the AFR work.. I need to change the one that does this as my idle is lumpy and my acceleration slightly hesitant and a good amount of black smoke at the top end?
