Results 1 to 10 of 29
Thread: 2.2 direct misfire/lack of power problems.
    Moray
    Default 2.2 direct misfire/lack of power problems.
    Hi guys, hope someone can shed some light on this for me.
    Car has been running fine until the other day, when all of a sudden it almost died, would take any revs above 2500 and limited itself to about 20 miles an hour.
    It also threw up the car and spanner light at the same time.
    This happened while my wife was driving it home, and luckily happened in town just after she came of the main NSL road.
    I took it out for a spin and all seemed fine, till you tried to give a bit of poke, where upon it would judder about, go very slowly up the rev range and have absolutely no power at all.
    Very dangerous to drive in this condition.
    Ive changed out all the filters, oil and plugs and still runs the same.
    I cleaned out the crankcase breather hose as well, and there was a bit of gunge in there too.
    Could it be the EGR? Ive had a look through my haynes manual but still not sure exactly where it is and the best way to get it off.
    Car has one 91,000 miles so far.
    Any help or pointers would be appreciated. Thanks.
    Moray
    Default update
    OK, got the RAC out today to have a look. Guy hooked up his laptop and got a few codes from the car.
    He cleared them then ran the car for a while giving it some revs every now and again till spanner light came back.
    Two codes kept reappearing each time P1191 fuel rail pressure and another one which he hasnt written down. Cant remeber it either but it was something to do with port solenoid / abs traction control and that had him stumped also.
    Seems like each time you unplug the MAF on my car , it throws up the traction control light on the dash.
    Had a bit of reading around here regarding p1191, and it would appear that there was a "silent" recall on the fuel pressure regulator on the 2.2 directs.
    Ill give them a call in the morning about it.
    Anyone any other ideas?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    you can check your chassis number against the recalls list on the VOSA website... i have read on here mentions of the fpr recall...
    http://www.dft.gov.uk/vosa/apps/recalls/default.asp
    Jan 2010
    glasgow
    hi mate yip there was and still is i think a fpr recall on the 2.2 that would be my first port of call and cross your fingers it sorts it if not you could be looking at a hp fuel pump as this is also a problem area in the 2.2 and 1 last bit of advice change the oil and oil filter every 5-10 k
    Moray
    Thanks for the replys guys. Will let you know in the morning .
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    if it throws up your asb light it will be the fuel pressure sensor there about 60 odd quid
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    My fuel pressure sensor has gone and I have no ABS light on the dash
    Aug 2010
    Luton
    when I spoke with dealer when I had problem he asked if light was on when I said yes he said that is one of the things it does so they (vaux techs) know its the sensor not the pump, weel thats what he told me
    Regular Member noel.nev's Avatar
    Pen-Y-Bryn S.Wales
    when my fpr went my car would not start, when it started to misfire and splutter it was the high pressure fuel pump hth
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    if its got a seimens high pressure fuel pump on it , it will probably be that, get it back to vaux and get a continental one put on my car did the same.
  1. 2.2 direct misfire
    By lh_4827 in forum Engine & Drivetrain
    Last Post: 22nd November 2013, 19:55
  2. Lack of power
    By McLovinH in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 22:17
  3. 2.2 Direct Misfire Problems :(
    By jonny180 in forum Engine & Drivetrain
    Last Post: 14th April 2012, 20:00
  4. 2.2 Direct 54 misfire sometimes
    By rodzynx in forum Engine & Drivetrain
    Last Post: 4th March 2012, 12:22
  5. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
