Results 1 to 10 of 11
Thread: Another post about Vacuum Pipes!
    Regular Member lostdog's Avatar
    Oct 2010
    Midlands
    Default Another post about Vacuum Pipes!
    Hello,
    I now have my new blue 2mm pipes.
    I tried to pull the old ones off, but they are stuck well tight!
    Do i need to do anything to get them off, or just pull as hard as i can.
    I don't want to break anything.............
    Regular Member Innes's Avatar
    Plymouth
    Trying doing it after a drive so the engine bay is warm/hot. This will help losen the old ones and put the new ones on. Failing that a bit of muscle never did any harm! Just make sure you have got hold of what ever you are tring to pull it off from!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    take though all the t pieces are plastic as are the actuattor connector pipes
    Regular Member eaglepva's Avatar
    Up North
    Maybe use a hairdryer to warm the plastic up, or place the plastic in some hot water to make it more softer to get the pipe on.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep all of the above and try to twist them a bit to break the seal too
    north east
    And if all that failes ... stanley knife
    Oct 2010
    Midlands
    I am back at Square one! Limp home mode. I drove for about 30 mins at 80mph on the motorway then, when I stopped at the next junction the stupid light (Limp home mode)came on!! Again!
    What would happen for the light to come on after driving at constant speed then coming to stop for the light to come on?
    Error code read, nothing to read! The guy with the reader could not find any codes......
    I want to smash this car into a wall.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by lostdog View Post
    I had a similar problem with my old 3.0CDTi. It was the EGR valve.
    Could be different in your case
    Engine : 2.0DTi
    Mileage : 73350
    Could also be one of the actuattor,s themselves going t/u. And they do not generate a fault code when they go
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Did you replace the EGR Valve? or clean it?
    Replaced with a new one
  1. Vacuum Pipes. 1.9 120. 2004 vectra c
    By carling in forum Engine & Drivetrain
    Last Post: 30th January 2013, 15:22
  2. vacuum pipes from pump
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 22:00
  3. P 0100 on vectra dti is back but my vacuum pipes intact!
    By yogishniz in forum Vectra C / Signum Troubleshooting
    Last Post: 12th July 2011, 10:37
  4. Do vacuum/boost pipes have to be a certain length
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 27th May 2011, 17:05
  5. Vacuum Pipes on Diesel engines
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 20:05
