Results 1 to 10 of 22
Thread: Remap Problems 1.9cdti 150
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    confused Remap Problems 1.9cdti 150
    A mate has had his car remaped but the figures are very strange,
    its a 1.9 150 which produced 147 bhp With FMIC and K&N panel, no remap.
    He had a map put on but the car will not produce over 173bhp no matter what the guy trys (its had about 10 different maps varying from 165bhp to this figure of 173bhp) It will not produce more than that, he said that with the software on this he's had people see 200bhp+
    strange thing is the torque figure 404 lb/ft
    He also said that the remapper was doing the runs in 5th gear?
    Does anyone know where he could go from here?
    (All above are at the fly)
    Regular Member lostdog's Avatar
    Oct 2010
    Midlands
    Default Another post about Vacuum Pipes!
    Hello,
    I now have my new blue 2mm pipes.
    I tried to pull the old ones off, but they are stuck well tight!
    Do i need to do anything to get them off, or just pull as hard as i can.
    I don't want to break anything.............
    Jun 2007
    Cheshire
    I take it that a mistake lol ^^
    we've had a re think about the 404 lb/ft...That's what the mapper said but we think that'll be Nm = 297 lb/ft. but apparently he was sure it was lb/ft ??
    it wouldn't produce that would it?
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    404lb of torque? You sure its lb ft and not NM? A mapped Z30DT does around 360-370lb ft (about 470NM). If it's kicking out 404 lb of torque then the DMF/Clutch/Gearbox will need changing around this time next week!!
    Sounds silly, but has he done the airbox mod? If the engine can't get enough air it won't produce the extra power also, what was the cooling like on the RR?
    Jun 2007
    Cheshire
    Think we posted pretty much the same time.
    That what i was thinking, i said to him are you sure and he said its what the mapper said, i told him to be on the safe side don't give it too much stick incase the gearbox falls apart lol.
    Air box mod has been done along with a K&N panel, just the big fan like usual, he even removed his grill so the airflow could go straight into the intake pipe.
    Could it be to do with running in 5th gear? The lad doing the remap was getting his maps from AMD and adjusts them himself he was on the phone to the person at AMD trying to sort it, so i cant see there being a problem with maps, just wondering if it something on the car causing the problem could the FMIC be a problem.
    Engine : 1.9 CDTi
    He needs to do it in 4th gear I think as thats a 1 to1 ratio.
    Jun 2007
    Cheshire
    Cheers for the info, would the run in 5th cause it to look lower on power?
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    never mind the bhp..................how does it feel to drive
    Jun 2007
    Cheshire
    Well previous to this he had another vectra with the EDS software RR'd at 192bhp... and it feels no where near as fast or good to drive!
    Jun 2009
    bradford
    Quote Originally Posted by SRI-150 View Post
    right so as a customer has he asked for his old map loading back on? and his money back? he will have a certain period to do this in I would have thought tho!...............who mapped it and how much
  1. 1.9cdti remap advice also would like a sport button fitted?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 16:31
  2. anyone know where to get a remap for signum 1.9cdti??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 20:03
  3. Replies: 17
    Last Post: 23rd July 2009, 10:48
  4. BSR remap now available for the 1.9CDTi
    By Duncan in forum Diesel Engine related
    Last Post: 27th September 2007, 20:36
remap problem with vectra c 1.9 cdti
vauxhall vectra 1.9 cdti sri 150 remap
vectra c 1.9 cdti remap
vectra c cdti remap
remapping a 1.9cdti
vectra c 1.9 cdti remap specs
vectra c 1.9 cdti 150 remap
