Results 1 to 2 of 2
Thread: 'Exhaust' light on!
    Dec 2010
    Cumbria
    Default 'Exhaust' light on!
    Car went into 'limp mode' and wouldn't let me go above 40mph. Got it home and opened the bonnet. I'm aware of the 3rd Injector problem so had a look. It needs changed to the after-mod type.
    Now heres the problem...
    The 'Exhaust Fault' (engine outline) lamp came on. After wiggling the 3rd injector wire the car now runs fine BUT the Engine Fault light stayed on.
    Am i right in thinking that because of the 3rd Inj fault the car would of been overun by diesel causing a problem with the Cat?
    Only travelled about 10miles in limp mode.
    If so, how do i get it 'normal'? Would a good blast on a straight road help?
    Any ideas guys? Only had the car 9 days!!
    Cheers in advance!!
    Sep 2009
    middlesbrough
    If the car is running fine again the emissions light will go out after a certain number of cycles of the ignition but you need to get the fault codes read to see what has caused the problem in the first place
  1. EML - Exhaust Emissions Light
    By liam8282 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2011, 21:08
  2. Spanner light 5 times now exhaust gas light
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 01:12
  3. Exhaust gas light
    By dans6490 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2009, 21:02
  4. Exhaust gases light on. :(
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2009, 19:36
  5. Exhaust Gas Warning Light On!
    By doncaster_mainline in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2008, 20:45
